Author Topic: Trimming Happ 27" Bezel  (Read 3543 times)
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
« on: November 16, 2003, 11:26:03 am »
Hig guys,
Goto trim the edges of my new bezel so it fits my cab.  What should I use to cut it? should I get a fine jigsaw blade.  Should I use the dremel? Or should I use and exacto knife.
Has anyone done this before and, could you tell me what you used to trim your bezel.  What would your reccomended approach be
Excuse my speeling :)
Off all the things I've lost I miss my mind the most!!
Madman
  • Last login:September 01, 2017, 01:03:20 pm
Re:Trimming Happ 27" Bezel
« Reply #1 on: November 16, 2003, 11:44:09 am »
I used a battery operated Ryobi circular saw with a fine blade and it came out perfect with no flaws~!
TalkingOctopus
    • My Arcade
« Reply #2 on: November 16, 2003, 12:06:48 pm »
I used a razorblade and a straight edge.  It worked well.
Inaba
  • Last login:December 14, 2004, 01:58:48 pm
  • Secret Squirrel
    • Cazic Thule Forums
« Reply #3 on: November 16, 2003, 05:01:25 pm »
I used a Dremel with a cutting bit, worked pretty well.  (Incidentally, this works wonders on thin, cheap Plexiglas as well)
SNAAAKE
  • -Banned-
« Reply #4 on: November 16, 2003, 05:56:39 pm »
Get a plexi glass cutter.I used that.
Use a ruler too.
« Last Edit: November 16, 2003, 06:02:13 pm by SNAAAKE »
davidsz
  • Last login:October 09, 2004, 11:55:54 am
« Reply #5 on: November 16, 2003, 11:14:03 pm »
I used a utility knife with a straight edge and it worked perfect.
I ran the knife across three times with a little pressure and it cut through real clean.
David
OSCAR
    • Oscar Controls
« Reply #6 on: November 16, 2003, 11:36:48 pm »
Yes, a razor knife and straight edge works very well for trimming these.  You don't even need to cut all the way through the bezel; just a single good pass with a sharp razor will score it, then it will snap right off.  If you make multiple passes, you might wander with the blade and then it becomes messy.  Make your first cut right on the money, then a simple bend & snap will leave a nice, clean edge.
vitaflo
  • Last login:January 14, 2020, 08:11:04 pm
    • ASMBLR
« Reply #7 on: November 17, 2003, 01:15:28 am »
I used a table saw.  Nice straight perfect cut.
SuckerFish
  • Last login:December 28, 2004, 10:43:16 am
« Reply #8 on: November 17, 2003, 02:56:18 pm »
Hi there new member but have been following the site and scene for a while  :)
My setup will be a capcom dynamo cab and i just bought a 27 inch jvc tv that i can measure , it will just fit into the cab.
Im looking towards getting the happs 27in bezel, but will it fit in my cab?
Because im going with a tv setup and not an arcade monitor.
Also is it always plexi that holds up the marquee? or will tempered glass work?
Nobody owns the plesure of tones, that belong to a guy with no ear.
aricade
    • Isaacade
« Reply #9 on: November 18, 2003, 09:25:15 am »
I'll measure the interior dimensions tonite when I get home.
It fit my 27" vision pro monitor perfectly,...
I remember seeing the dimensions on someones homepage berfore.  Just dont recall were...  If someon can recall that...
Cheers
Aricade
TalkingOctopus
    • My Arcade
« Reply #10 on: November 18, 2003, 06:30:18 pm »
I used a happ 27" bezel with a  27" sharp tv.  It fit just fine.
I think either plexi or tempered glass would work.  I used very thin lexan for the front and a piece of white posterboard for the back.
aricade
    • Isaacade
« Reply #11 on: November 18, 2003, 10:21:17 pm »
Width 21"  heighth 16"
