Author Topic: help got a hyperball and problems with score display  (Read 2623 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: August 11, 2013, 06:27:29 pm »
So ihave a a hyperball machine that I have a problem with the score and info displays. All of them are not displaying all of the digits and letters. Its weird cause they kind of flicker a bit on the numbers of the score and when the name hyperball comes up on the Playfield it is missing letters. When I hooked it back up from moving it to my house it worked fine for like 5 mins. Then it started to flicker and disappear. I've changed the power supply and the game works fine just displays not working right.
GMZombie
Re: help got a hyperball and problems with score display
« Reply #1 on: August 11, 2013, 11:14:05 pm »
i think i have an idea of where to start as i was looking at the manual and it has schematics of the cpu board and there is a place where the wires hook up for the bcd display and another display output. possible just a bad solder joint which im hoping for.
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« Reply #2 on: August 12, 2013, 08:28:09 am »
If its not the connectors.. it could be you High Voltage Power Supply.
If not the supply then the glass display itself is bad.
I just had this problem on the Player 4 display on the STARS game I am working on.
Segment 'D' would initially come on bright and then flicker after a minute or two...very frustrating.
GMZombie
« Reply #3 on: August 12, 2013, 07:37:33 pm »
I havent gotten a chance to recheck it but all 3 displays are acting up so i doubt they all went out at the same time..but it is a hyperball so u never know..lol
« Reply #4 on: August 13, 2013, 11:00:54 am »
That sonds very very much like a connector/header issue.  The displays in that game are daisy chained for the most part.  Resolder the headers on all of the displays and repin all of the connectors.  Do it on the driver board, too.  That should take care of this.
