Author Topic: Monitor Discharging Problem?  (Read 1535 times)
null
  • Last login:January 13, 2004, 04:00:53 pm
« on: November 15, 2003, 08:28:29 pm »
I was trying to discharge a Wells-Gardner 19k4921 19" arcade monitor with the alligator clips on the ends of heavy gauge speaker wire with screwdrivers in the clips. I used the ground port on a electrical outlet as the ground. When I slipped the screwdriver under the suction cup on the back of the monitor I didn't hear a sound, I did this a few times and was wondering if it would be safe to take out now and/or possibly that this type of monitor is self-discharging?
Thanks in advance,
Hallie
menace
Re:Monitor Discharging Problem?
« Reply #1 on: November 16, 2003, 10:55:24 am »
Ok STOP!!!  You're monitor is likely not discharged!!!  You have to ground the tube to its internal ground and not an external one.  Think of the tube as a large capacitor you have to short across the terminals to discharge it.  What you did would be equivalent to going next door and grounding to their outlet--i.e. no effect whatsoever on the charge in your tube!!
You have to hook one end of the the aligator clips up to the monitor frame and then the other to a screwdriver which you insert under the suction cup to discharge the monitor.  keep one hand in your pocket as you do this and make sure that you don't touch ANYTHING!!!.
