Author Topic: ACT LABS GUN VGA VERSION WORK ON 15 KHZ CRT TV  (Read 1494 times)
gibranx
  • Last login:June 14, 2022, 11:38:50 am
« on: August 04, 2013, 12:00:30 am »
i have two act labs gun vga box version (the first version of gun, space design style)
i have ati 9800 pro with crt emudrive 6,5    soft 15 khz and vga scart cable on 21" crt tv akai win xp3
if you use the gun vga box with only vga scartcable, in my case the gun dont work.
i have buy this converter and the gun work:
http://www.amazon.it/LEICKE-KanaaN-Convertitore-suVfficiente-alimentazione/dp/B003U0PHC8/ref=pd_sim_sbs_ce_4
first plug the converter in to the vga PC
then plug the vga cable of the gun on the VGA IN on the converter
last plug the vga scart cable on the VGA OUTof the converter
The act labs gun calibration work only in 5/6 resolution tested with OSD or switch res, but in 640x480 dont work!
infact if you play point blank on mame in native resolution the gun calibrate and work.
the converter dont modify the quality signal of the vga scart cable.
