Author Topic: ArcadeVGA3000 or HD4500?  (Read 2297 times)
Be77amy
  • Newbie
  • Last login:October 18, 2013, 10:05:01 am
« on: August 01, 2013, 08:31:41 pm »
Hi, so basically the situation I'm currently in is as follows: Ive got my machine set up running GroovyMAME + ArcadeVGA3000 with ultimarc drivers + J-PAC + Hantarex MTC 9000 + win7. I've just came into possession of an ATI HD4500 graphics card and I've read that these are more configurable than the AVGA3000's. My question is is it worth changing the cards over and if i was to do so whats the best way to set it up with regard to which version of windows, calamity drivers? soft15? etc.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: ArcadeVGA3000 or HD4500?
« Reply #1 on: August 01, 2013, 10:28:53 pm »
Right at this moment if you don't use the AVGA then you will probably need to go back to Windows XP
you do get more resolutions available.. but whether you need more than the AVGA supplies.. I don't know
Calamity
  • Moderator
  • Last login:Today at 08:51:19 am
  • Quote me with care
« Reply #2 on: August 02, 2013, 06:08:05 am »
If you're happy with your AVGA then there's no need to change. I just found my old AVGA seriously limited when it came to supporting certain resolutions & refresh rates which I consider fundamental (Irem games). Some people just run everything at 60 Hz and are quite happy anyway.
Yes, until CRT Emudriver for W7 is released, which should happen soon, you'll need use Windows XP.
Steps to create a log:
rCadeGaming
  • Just call me Rob!
« Reply #3 on: August 03, 2013, 11:01:15 pm »
Arcadevga or Radeon?  Radeon.
