Author Topic: Arcade VGA ArcadePerfect?  (Read 1247 times)
rawbe
  • Last login:June 17, 2025, 05:54:46 pm
« on: August 01, 2013, 04:06:20 pm »
I posted this in software but no bites soooo:
Will the Arcade VGA ArcadePerfect Utility work with an Arcade VGA2 card? I have tried installing the program but I keep getting an error that states "No Card Found"
The drivers are working properly plus the card hasn't had any problems up to this point . Any info is appreciated!
Robbie
Re: Arcade VGA ArcadePerfect?
« Reply #1 on: August 02, 2013, 12:10:30 pm »
ArcadePerfect seems to be for the AVGA3000. If by ArcadeVGA2 you mean the earlier AGP version (based on Radeon 9200 IIRC?) then no, it will not work AFAIK.
rawbe
« Reply #2 on: August 06, 2013, 11:34:41 am »
Minwah-
Thanks for the info. You are right. Arcade Perfect will not work on the older cards unfortunately.
Robbie
