Author Topic: HLSL brurry  (Read 1428 times)
mamenewb100
  • Last login:April 01, 2022, 03:32:29 pm
HLSL brurry
« on: July 31, 2013, 12:19:53 pm »
Ever since I upgraded to the newer HLSL in MESS .149, I've been trying to get a sharp picture but haven't been able to. I've removed all the blooming effects and just want basic settings with no blur or effects. Is there something that I'm missing that has to be on?
The whole image is fuzzy compared to non-HLSL which is sharper. I don't have any filters on or anything.
Life is a Game and we are all being Played.
cmoses
HLSL brurry
« Reply #1 on: July 31, 2013, 02:45:27 pm »
Post your HLSL section from your MAME.ini file. That will help a lot.
Sent from my iPad Mini using Tapatalk HD
mamenewb100
Re: HLSL brurry
« Reply #2 on: July 31, 2013, 09:14:07 pm »
Sorry about that. Wasn't at my PC at the time.  ::)
I'm actually using a CRT for HLSL. If your wondering why it's because I'm emulating the Atari Lynx portable that has a resolution way too low for a regular CRT. So I just have the resolution doubled and the scanlines are only half of what they should be leaded to blocky picture. In HLSL it can emulate the scanlines at any resolution and the Lynx games look MUCH better, except for being blurry than normal.
I don't want any special effects since I'm already using a CRT. Just want a vanilla non-blurred screen.
« Last Edit: July 31, 2013, 09:16:29 pm by mamenewb100 »
Rigby
  • Last login:August 26, 2014, 09:40:59 am
  • I am good at liking video games
Re: HLSL brurry
« Reply #3 on: August 01, 2013, 10:01:19 am »
set hlsl_enable to "0"
  • Last login:Today at 04:12:19 pm
Re: HLSL brurry
« Reply #4 on: August 01, 2013, 12:43:40 pm »
No he wants to use hlsl, just without any blurring effects, which totally defeats the purpose.
I understand the situation but what you need to understand is that hlsl isn't meant to do what you want it to do. I mean technically it might be possible to use hlsl effects with zero blurring, but I doubt you'll get a 100% crisp picture. You don't want to use hlsl, that isn't going to get the job done.  What you need is the "effect" command, which will load a png mask over the running game simulating scanlines or whatever you desire.  There are tons of pre-built masks out there or you can build your own.  Good luck!
