Author Topic: saving threads?  (Read 1091 times)
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
saving threads?
« on: July 30, 2013, 10:27:26 am »
Is there a way to save threads as favorites on this forum?
I've been perusing the archives and it would be a nice feature to save threads that are interesting to the reader.
Bookmarking them would work, but I read this forum on several machines.
Thanks again for providing this great resource.
severdhed
  • RIP Dinosaur Hippo
Re: saving threads?
« Reply #1 on: July 30, 2013, 10:31:59 am »
I'm not sure if there is a way to do that or not.  You can click the Notify button, which will email you when someone replies to a thread you are interested in.   If you start using google chrome as your browser, then  your bookmarks would sync across all of your devices.
  • Last login:January 29, 2026, 12:04:48 pm
Re: saving threads?
« Reply #2 on: July 30, 2013, 10:35:49 am »
Above the thread on the right, there should be an "Add Bookmark" button.
In the top section, just below your avatar, there is a "My Bookmarks" tab.
This is on the forum, not on your PC and will be available wherever you are signed in.
I think this may vary by the forum theme you are using.
I'm using the default (Curve)
The theme can be changed under Profile>Account Settings>Look and Layout
Re: saving threads?
« Reply #3 on: July 30, 2013, 11:37:06 am »
Yeah, IIRC, there was a theme where the bookmark feature was completely missing. If in doubt, change theme.
michelevit
Re: saving threads?
« Reply #4 on: July 30, 2013, 11:58:24 am »
THANKS!!!
i changed themes and sure enough a bookmark button appeared just like you suggested.
That makes things much easier. Now I can bookmark away.
I never knew you could change themes. The default theme does not have the bookmark button.
