Author Topic: Mamewah 1.69 is it still working?  (Read 2153 times)
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« on: July 28, 2013, 10:27:30 pm »
I'm trying to upgrade my cabinet from a pre 1.61 version of Mamewah. I'm running Windows XP. I've tried 2 machines and I get the same errors. Right now I'm only trying to get Mame working.
When I launch Mamewah it starts off on MAME with "JoyStick Games" selected. When I hit TAB the Options window opens, but it's empty. If I press the 1 key while the empty Options window is open I get an internal error.
I made no changes to mamewah.ini
Here's my mame.ini:
Code: [Select]
### mame.ini (mamewah v1.69) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  c:\progra~1\mame\roms
rom_extension                             zip
dat_file                                  c:\progra~1\mame\mame.dat
nms_file
catver_ini_file                           c:\progra~1\mame\catver.ini
list_generation_method                    dat_file
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\progra~1\mame\mamepp.exe [name]{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\progra~1\mame\snap
movie_preview_path                        c:\progra~1\mame\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              1
MameWah Log file:
Code: [Select]
7/28/2013 7:09:32 PM MAMEWAH v1.69 launched
7/28/2013 7:09:32 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/28/2013 7:09:32 PM Desktop colour: 9981440
7/28/2013 7:09:32 PM Wallpaper filename: C:\WINDOWS\web\wallpaper\Bliss.bmp
7/28/2013 7:09:32 PM Desktop display mode: 1047x785 @ 60Hz, 32bit colour
7/28/2013 7:09:32 PM Decimal symbol: '.'
7/28/2013 7:09:33 PM Games list read: fusion-0.lst
7/28/2013 7:09:34 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/28/2013 7:09:34 PM Layout selected: C:\Program Files\mamewah\config\layout.lay
7/28/2013 7:09:34 PM No. joystick devices attached: 0
7/28/2013 7:09:34 PM Ctrlr file selected: C:\Program Files\mamewah\config\mamewah.cfg
7/28/2013 7:09:34 PM Keyboard enabled
7/28/2013 7:16:28 PM MAMEWAH v1.69 launched
7/28/2013 7:16:28 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/28/2013 7:16:28 PM Desktop colour: 9981440
7/28/2013 7:16:28 PM Wallpaper filename:
7/28/2013 7:16:28 PM Desktop display mode: 800x600 @ 60Hz, 32bit colour
7/28/2013 7:16:28 PM Decimal symbol: '.'
7/28/2013 7:16:28 PM Games list read: mame-1.lst
7/28/2013 7:16:29 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/28/2013 7:16:29 PM Layout selected: C:\Program Files\mamewah\config\layout.lay
7/28/2013 7:16:29 PM No. joystick devices attached: 0
7/28/2013 7:16:29 PM Ctrlr file selected: C:\Program Files\mamewah\config\mamewah.cfg
7/28/2013 7:16:29 PM Keyboard enabled
7/28/2013 7:16:32 PM Error: 9 Subscript out of range in CTRLR_ActivateEvent
7/28/2013 7:16:39 PM Mode 800 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
7/28/2013 7:16:40 PM MAMEWAH quit
7/28/2013 7:17:08 PM MAMEWAH v1.69 launched
7/28/2013 7:17:08 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/28/2013 7:17:08 PM Desktop colour: 9981440
7/28/2013 7:17:08 PM Wallpaper filename:
7/28/2013 7:17:08 PM Desktop display mode: 800x600 @ 60Hz, 32bit colour
7/28/2013 7:17:08 PM Decimal symbol: '.'
7/28/2013 7:17:08 PM Games list read: mame-1.lst
7/28/2013 7:17:09 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/28/2013 7:17:09 PM Layout selected: C:\Program Files\mamewah\config\layout.lay
7/28/2013 7:17:09 PM No. joystick devices attached: 0
7/28/2013 7:17:09 PM Ctrlr file selected: C:\Program Files\mamewah\config\mamewah.cfg
7/28/2013 7:17:09 PM Keyboard enabled
7/28/2013 7:21:15 PM Error: 9 Subscript out of range in frmOptions:OP_MENU_SELECT
7/28/2013 7:21:22 PM Mode 800 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
7/28/2013 7:21:23 PM MAMEWAH quit
7/28/2013 7:22:06 PM MAMEWAH v1.69 launched
7/28/2013 7:22:06 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
7/28/2013 7:22:06 PM Desktop colour: 9981440
7/28/2013 7:22:06 PM Wallpaper filename:
7/28/2013 7:22:06 PM Desktop display mode: 800x600 @ 60Hz, 32bit colour
7/28/2013 7:22:06 PM Decimal symbol: '.'
7/28/2013 7:22:06 PM Games list read: mame-1.lst
7/28/2013 7:22:07 PM Mode 640 x 480 @ 60Hz, 16bit colour selected after 2 attempt(s) at 1/2 second intervals.
7/28/2013 7:22:07 PM Layout selected: C:\Program Files\mamewah\config\layout.lay
7/28/2013 7:22:07 PM No. joystick devices attached: 0
7/28/2013 7:22:07 PM Ctrlr file selected: C:\Program Files\mamewah\config\mamewah.cfg
7/28/2013 7:22:07 PM Keyboard enabled
7/28/2013 7:23:42 PM Error: 9 Subscript out of range in frmOptions:OP_MENU_SELECT
7/28/2013 7:23:49 PM Mode 800 x 600 @ 60Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
7/28/2013 7:23:50 PM MAMEWAH quit
I did run the system files setup.bat and I even reboot. Same problem on both machines.
Joseph Elwell.
jelwell
Re: Mamewah 1.69 is it still working?
« Reply #1 on: July 28, 2013, 10:38:32 pm »
My bad.  :blah: I was supposed to be hitting 2 not TAB.
Joseph Elwell.
