March 09, 2026, 11:29:38 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Woodworking
Slot cut fix
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Slot cut fix (Read 3720 times)
reptar111
Trade Count:
0
Jr. Member
Offline
Last login:July 28, 2013, 09:25:48 pm
I want to build my own arcade controls!
Slot cut fix
on:
July 28, 2013, 05:49:54 pm »
Hi,
I recently routered the edges of my cabinet with the correct slot cutter to place my t-moulding into. The whole cabinet is great except for one section where the router was held at the wrong angle and subsequently the slot is too wide for the t-moulding to anker into. I have tried using a wood filler. This appeared to work great until i pushed the t-moulding into the new cut slot and disloged all the wood filler. Is there something stronger I can use to fill the extra wide slot which wont dislodge (a resin or something)?
Cheers
Logged
wordsworth
Trade Count:
0
Full Member
Offline
Last login:March 01, 2026, 03:05:28 am
...was severely wounded, but the soul still burns
Re: Slot cut fix
Reply #1 on:
July 28, 2013, 07:26:31 pm »
I've seen a lot of posters here on the forum using Bondo (auto body filler) with great success. You can probably fill up the whole slot and let it dry and then rout it again. Hope this helps.
Logged
Galaga Father Son Project
reptar111
Trade Count:
0
Jr. Member
Offline
Re: Slot cut fix
Reply #2 on:
July 28, 2013, 08:31:46 pm »
I hope it is strong because when i go to push to T-moulding back into the new cut, the timber putty i was using, sheers off the sides...
I'll give it a go.
Thankyou.
Logged
JDFan
Trade Count:
+1
Full Member
Offline
Last login:March 03, 2025, 10:29:54 am
Re: Slot cut fix
Reply #3 on:
July 28, 2013, 09:00:41 pm »
IF it isn't too big of a section Wood Glue should work -- just put some wood glue into the let partially dry so it thickens a bit then put the t-molding into place (wipe off excess glue the oozes out) and then use something to hold it in place while it dries (ie. a spare piece of wood with a couple clamps to hold the t molding into place in the slot)
Logged
wordsworth
Trade Count:
0
Full Member
Offline
Re: Slot cut fix
Reply #4 on:
July 28, 2013, 09:30:45 pm »
I've also read that a hot glue gun works wonders to hold the T-molding in small sections. Might be worth a try (if you have one) before you set out on a more lengthy repair.
Logged
a1pharm
Trade Count:
0
Full Member
Offline
Last login:November 15, 2025, 04:26:48 pm
Planning and preparation prevents problems
Re: Slot cut fix
Reply #5 on:
July 29, 2013, 10:17:59 am »
The same thing happened to me during my build. I used Gorilla glue, pushed the T-molding into the large slot, clamped it, and it has been holding up and looking great for months.
Logged
Shameless self bump (full cab):
http://forum.arcadecontrols.com/index.php/topic,129725.0/all.html
Shameless self bump (bartop):
http://forum.arcadecontrols.com/index.php/topic,134037.0.html
Shameless self bump (commissioned cab):
http://forum.arcadecontrols.com/index.php/topic,143724.0.html
michelevit
Trade Count:
0
Full Member
Offline
Last login:December 25, 2024, 06:57:41 pm
Re: Slot cut fix
Reply #6 on:
July 29, 2013, 10:28:26 am »
Hot glue is all you need. Its plenty strong and once dry its properties are like medium/hard rubber. A hot glue gun should be in everyone's tool box.
Logged
barryabrams
Trade Count:
0
Full Member
Offline
Last login:November 11, 2025, 12:50:36 pm
Re: Slot cut fix
Reply #7 on:
August 01, 2013, 02:26:32 pm »
You can take pieces of paper... any thickness between news paper and card stock and stick it in the crack enough so that the moulding doesn't come out. Then super glue it in place, and trim any excess paper. I've fixed a few this way. Just try not to get any superglue on the top of the moulding or on your fingers.
Logged
Minwah
Trade Count:
+3
Full Member
Offline
Last login:January 18, 2019, 05:03:20 am
Re: Slot cut fix
Reply #8 on:
August 02, 2013, 06:09:16 am »
I had a similar problem when I hadn't tightened the slot cutting bit properly in the chuck (it was difficult to do this with my small trimmer router)...it moved so I ended up with a groove not in the centre.
I used car body filler (same as Bondo I think), and it worked great...I just re-routed the cut afterwards. I was a bit worried it would break out when putting the t-molding in but it was fine.
Logged
MAMEWAH - Multiple Emulator Front-End
Mr. Dude
Trade Count:
+1
Full Member
Offline
Last login:March 03, 2019, 05:12:50 am
Hi...
Re: Slot cut fix
Reply #9 on:
August 02, 2013, 12:36:08 pm »
I had this problem on my last cabinet as well. I used some 5 minute epoxy to fix the problem. This stuff is nice and strong and gives a good bond.
http://www.homedepot.com/p/Loctite-0-47-fl-oz-Five-Minute-Instant-Mix-Epoxy-1365868/202020459
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Woodworking
Slot cut fix
