Author Topic: Pushbuttons compatible with Nintendo VS Controller?  (Read 1255 times)
MastarArcade
  • Last login:May 20, 2014, 02:42:08 pm
« on: July 25, 2013, 04:26:14 pm »
Recently I picked up a Nintendo VS Cabinet that was a DK conversion... and I'm thinking about making a few improvements.
One of the things I'm looking to replace is the push buttons... but per my poking around, I noticed that there is a diameter difference between most standard push buttons and the "Nintendo style."  It looks like the standard Nintendo buttons are  1 1/16" (~27mm) as opposed to what seems to be normal 35mm.
I plan to use this controller and it is made of metal (see http://forums.arcade-museum.com/showthread.php?t=97618 for reference)... so I don't want to get in to a situation where I have to bore out the holes more just to fit in a new button, that would just be too much headache.
So to save me a bit of investigation, has anyone replaced the push buttons on a metal Nintendo VS Control panel? If so, are there any "non-Nintendo" alternatives with the stock holes?
Thanks in advance!
  • Last login:Today at 12:45:31 am
Re: Pushbuttons compatible with Nintendo VS Controller?
« Reply #1 on: July 25, 2013, 08:28:10 pm »
Welcome aboard, MastarArcade.
The first important measurement for buttons is the mounting hole diameter.
The normal size for arcade pushbutton holes is 1 1/8" (~28mm) -- some Japanese buttons use 30mm holes.
Not sure where you got 35mm from -- sounds too large for the hole but it may be the size of the button bezel. (top of the body)  :dunno
Standard 1 1/8" Happ/IL button bezels are ~33mm.
As long as the button bezel covers the mounting hole, it will look fine.
MastarArcade
« Reply #2 on: July 26, 2013, 12:21:34 am »
Thanks for the response! I appreciate the info.
I took a closer look today when I got home and think I'm just going to go with the some different color Nintendo buttons from Mike's Arcade for now. Maybe later if I decide to get a bit fancier (and some more time), I'll mix it up with custom cut panel and perhaps some LED push buttons :)
MastarArcade
« Reply #3 on: July 30, 2013, 01:35:58 pm »
So after a bit more poking around at Mike's, I don't think he has the colors I'm looking for.
Anyone else know of an alternative source for "Nintendo compatible" push buttons?
MastarArcade
« Reply #4 on: August 16, 2013, 11:25:48 am »
Since I asked, and had a hard time finding the info, now that I have some results. I'll post them for those in the same boat.
The Groovy Game Gear CLASSX push buttons DO fit in to the 1 1/16" diameter Nintendo control panels. No shaving down of the plastic or additional boring out of the holes was required.  ;D
