Author Topic: Mame not saving key mappings...  (Read 3075 times)
IG-88
« on: July 23, 2013, 04:17:12 pm »
Anybody run into this issue before? I am running an older version (v75) of mame in XP and for the life of me I cannot get the pause button to stay remapped to a different key. It will work while I stay in the game but as soon as I exit and re-start it "defaults" back to the "P" button again.
I thought maybe it had something to do with the folders being read only but it saves high scores perfectly fine, so its allowing those files to be re-written.
When I try to change the Mame folder and un-set read only, it goes thru the whole process of changing itself and the files within, but when I check it's properties as soon as it's finished it still has the "read only" box checked. Very strange.
There should be an easy fix for this. Where does Mame save the changes to key mappings? Isn't it an .ini file somewhere?
-HarumaN
Endprodukt
  • Last login:Yesterday at 10:49:08 am
Re: Mame not saving key mappings...
« Reply #1 on: July 23, 2013, 05:31:48 pm »
Why wouldn anyone use such an old version of mame?
« Reply #2 on: July 23, 2013, 06:12:25 pm »
If you have an active controller file that your using, and it defines the pause button, it'll override what you define in the config ui, so even though you save it, when you go back and view it the value from the controller file will still be there.
Other than that, it could just be an issue with the older mame.
« Reply #3 on: July 23, 2013, 06:31:05 pm »
At least they stated they were using an old version.  :cheers:
Nothing worse than wasting time explaining features that aren't in their build.
Using MicroXP and not mentioning it is another one that gets me.
IG-88
« Reply #4 on: July 23, 2013, 06:32:40 pm »
It's worked before. And on older versions of Mame. I don't have controller file that I set up. I went into the ctrlr folder in mame and changed the std.ini file to the keystroke that I wanted but that didn't do it either.
Do you know where Mame stores the keystroke changes? Is it an .ini file somewhere?
 Because thats what I have and it runs the games perfectly on the older computer I'm using. Nothing has come out since then that worth a crap IMO anyways.
-HarumaN
IG-88
« Reply #5 on: July 23, 2013, 06:37:32 pm »
Ha! It just so happens that's the O/S. That my issue?
-HarumaN
cack01
  • Last login:January 31, 2023, 11:49:55 pm
« Reply #6 on: July 24, 2013, 07:41:49 pm »
Are you using a front-end or other 3rd party app?  AFAIK mame will not save unless you have a clean exit (i.e. you press esc and mame goes through its own exit routine). If you have a front end, pressing esc will sometimes cause the front-end to force close MAME and thus the exit routine is not ran.
IG-88
« Reply #7 on: July 25, 2013, 01:44:13 pm »
Good idea. I'm running Mala. I will try that out later today.
-HarumaN
keilmillerjr
  • Web Developer.
« Reply #8 on: July 25, 2013, 04:02:36 pm »
I'm not fully understanding what you are trying to do, so it's hard for me to understand what is happening. Shoot me a pm if you have a ichat/imessage or something.
