Author Topic: Number of buttons?  (Read 2504 times)
steved61
  • Last login:October 19, 2025, 01:05:53 pm
Number of buttons?
« on: July 22, 2013, 10:09:45 pm »
What emulators require more than 7 buttons?  Thanks
steved61
keilmillerjr
  • Web Developer.
Re: Number of buttons?
« Reply #1 on: July 23, 2013, 12:08:49 am »
N64 has a ---steaming pile of meadow muffin--- load.
DaveMMR
« Reply #2 on: July 23, 2013, 12:14:52 am »
Kind of a broad question... no emulator requires a set number of buttons. It's the individual games that make these demands.
If you're limited to seven buttons (does that include any start buttons? coin buttons? is there a keyboard handy?) you've good up to about SNES (if you don't need "select.") You're limited with Colecovision, Intellivision and Jaguar games that need a keypad to play (I know that's all of 'em for Coleco, the keypad starts the game.) PSX and newer consoles: you'll have a bit of limitation.
What exactly are you looking to play? Start with that.
  • Last login:Today at 10:21:07 pm
« Reply #3 on: July 23, 2013, 05:43:22 am »
7 is all you need.  (not counting start ect).  That 7th button would just be an option for a "run" button in the mk games and a 4th button on your bottom row for neo-geo.
Any game that requires more than 7 is going to need analog controls to play, which is irrelevant for an arcade control panel.
Also if you were planning on a 4 player setup (btw do NOT plan on that... totally not worth it) player three and 4 only need 4.  The higher the number of players, the fewer buttons used.  That for the most part applies to boht consoles and arcade games.
Brian74
  • Yep... I built that!!
« Reply #4 on: July 23, 2013, 07:14:33 am »
I am going with 8, only because I will be playing my PS3 and xbox 360.
Sent from my SGH-T989 using Tapatalk 2
steved61
« Reply #5 on: July 23, 2013, 12:01:29 pm »
Thanks all I will use a 7 button layout for my controller. I'll be  using separate buttons for admin, coin and player starts.
Steved61
