Author Topic: Mini PAC mouse inputs only respond once  (Read 864 times)
gurusi
  • Last login:April 19, 2014, 09:10:48 am
« on: July 17, 2013, 08:26:50 am »
Hi, my control panel is almost setup with exception of the mouse inputs. I have them setup as per other posts (extension wire used in empty housing to the correct inputs).
The inputs/left & right buttons only work once. After that they are non responsive unless I unplug the minipac from the USB and back in again. After that they only work once again.
I have tried disconnecting my Bluetooth mouse from start up but it makes no diference.
The inputs and wiring must be fine for them to respond initially, but I can't figure out what's stopping them after that....
I am running xp and using ultralux buttons. I also have a utrak and spinner connected via the mini pac
Hootee
  • Newbie
  • Last login:February 17, 2015, 01:20:54 am
Re: Mini PAC mouse inputs only respond once
« Reply #1 on: July 21, 2013, 03:41:20 am »
I have the same problem. Mouse buttons works just once. After that not even my regular mouse(usb) buttons work in linux. In Windows regular mouse buttons still works.
I have tested with Windows 7 and Linux.
If somebody have solved this please answer.
Thanks.
