Author Topic: U-Trak question  (Read 820 times)
epac90
  • Last login:July 09, 2013, 03:28:42 pm
U-Trak question
« on: July 09, 2013, 02:59:44 pm »
So I went to hook up my U-Trak last night to my optipac, and I noticed that one of the connections did not have a black cable (ground) going to the 4 pin connector.  Is the ground between the 2 connections just a common ground?  Or are they isolated?  I'm assuming if they're connected I can just make a jumper from one connection ground to the other.
  • Last login:Today at 04:07:00 am
Re: U-Trak question
« Reply #1 on: July 09, 2013, 03:10:42 pm »
You are correct.
The ground connects to both optical boards inside the UTrak.
epac90
Re: U-Trak question
« Reply #2 on: July 09, 2013, 03:13:30 pm »
Awesome, thank PL1.  Really didn't wanna have to disassemble it to solder a wire to the board.  I'll just make a jumper then  :cheers:
