Author Topic: Need some noob control help  (Read 971 times)
stoopid2001
  • Last login:February 12, 2019, 09:12:05 pm
« on: July 07, 2013, 02:17:34 pm »
I just put most of a bartop together and I massively screwed up my control settings on a few levels.  I have a 2 player setup with 6 buttons each and 6 admin buttons(1P start, 1P coin, 2P start, 2P coin).  I'm using an Ipac 4 and I wired the 2 "extra" admin buttons to 3P start and 3P coin.  I want to use 3p start and 3p coin as more useful buttons in hyperspin.  This is where I screwed something up.....I used winipac to try to remap/reassign/resomething 3p start and coin.  I ended up remaping my whole control panel as different inputs, some overlapping.  In the middle of all that (when I thought I had fixed it) I tried to change some input settings in hyperspin, then in MAME through the tab menu.  All I want to do now is start over. Can I just delete and re install hyperspin, MAME and winipac or is there an easy fix that i'm just missing?
Any help would be appreciated.
darkSSide
  • Last login:March 24, 2024, 08:19:48 pm
  • I want to make my own money!
Re: Need some noob control help
« Reply #1 on: July 07, 2013, 03:49:35 pm »
I believe if you have an original copy of your config from whatever MAME your running,just copy and paste to your config folder to replace the one you screwed up.
Sent from my Atari 2600
