Author Topic: getting copied bezel to stay flat  (Read 2515 times)
timmyjimmy5150
  • Last login:November 14, 2003, 07:50:16 am
« on: November 14, 2003, 07:53:28 am »
Hi all.....
I laser printed the bezel artwork for my galaga machine.
I was planning to place the color copy on the underside of the glass bezel on my game.
What's the best way to get the bezel to adhere to the glass?  Are there any adhering agents that work better than others.......  I tried putting it in w/o any agents (glue, etc) and the artwork obviously won't lie flat.
Any help appreciated
tim
ErikRuud
Re:getting copied bezel to stay flat
« Reply #1 on: November 14, 2003, 01:36:26 pm »
I don't think you will be able to glue your artwork to the backside of the glass and get it to look good.
You could glue it to the front side of a thin sheet of plexiglass, and then put that behind your glass.
American Laser Games Wrapper
O2em Rom Utility
walls83
  • beer is good
« Reply #2 on: November 14, 2003, 03:29:05 pm »
have you tried to use poster board behind it..?  I dont know if this will work but its what I am thinking about trying.  Just cut the poster board out the same size as the bezel and stick it behind the bezel.  Its cheap to try atleast and if it doesnt work you didnt destroy your bezel trying to do it.  Just a thought
Jakobud
  • Last login:Today at 10:09:01 am
« Reply #3 on: November 14, 2003, 07:39:35 pm »
Hmmm well a lot of glues or adhesives or epoxies, while look colored, dry clear. But i still don't think it will look good.
Radical
  • Last login:March 12, 2022, 03:39:21 pm
  • Yes
« Reply #4 on: November 18, 2003, 12:42:11 pm »
I used a piece of foam-core board.   It's basically two pieces of poster board with thin foam glued in the middle.   This stuff is very rigid.
I cut out the center of the foam board then I glued the bezel to it.  Then it went behind the 'glass.
I got mine at the local Eckard drug store but most art supply stores carry it in various colors.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #5 on: November 26, 2003, 03:45:17 pm »
you can get it real cheap at target too
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #6 on: December 02, 2003, 08:39:04 pm »
I gotta agree...glueing it directly to the glass will look like ass.  Glue the back to something stiffer (poster board, styro board) and put that up to the glass.
Stingray
« Reply #7 on: December 16, 2003, 01:37:50 pm »
Is there a reason why it couldn be sandwiched between two sheets of glass? That's what I had in mind for mine.
-S
