Author Topic: What are the settings for GM to use with an LCD, HLSL, LCD-Setup?  (Read 3774 times)
Endprodukt
  • Last login:November 28, 2025, 03:54:23 pm
So,
I want the advantages of GM for scrolling etc. while using HLSL on a LCD screen (it's for a bartop - no space for a crt this time). What's the way to setup GM for this? I have great HLSL settings,
I just need the GM basics for this.
Thanks in advance
  • Last login:Today at 03:57:15 am
Re: What are the settings for GM to use with an LCD, HLSL, LCD-Setup?
« Reply #1 on: June 24, 2013, 05:17:09 pm »
All you have to do is set the HLSL as usual, then:
monitor lcd
syncrefresh 1
Forcing -syncrefresh here makes all games run at 60 Hz (assuming a typical 60 Hz LCD). If you don't want this, i.e. keep games running at their native refresh if it's not close enough to 60 Hz, then leave -syncrefresh alone (default = 0), this will toggle either -syncrefresh or -triplebuffer depending on how close the native refresh is from 60 Hz. The threshold is controlled by the -syncrefresh_tolerance option (default = 0.2 Hz). Obviously, if you don't force -syncrefresh, you can expect scroll hiccups in games that don't run at 60 Hz, although you'll have no tearing.
The "monitor lcd" option also imposes that MAME will run everything at your current desktop resolution, which ideally equals your LCD's native resolution when you're using an LCD. I'm telling this because, quite often, users have to force MAME to pick a lower resolution than the native one in order to get HLSL run at full speed. If this is the case, then the "monitor lcd" is a bit of a problem, because it expects not to switch resolutions. What you have to do in this case is to lower the desktop resolution instead to the desired one for HLSL to work.
« Last Edit: June 24, 2013, 05:19:10 pm by Calamity »
Endprodukt
« Reply #2 on: June 25, 2013, 12:05:14 pm »
I get pretty bad vertical and horizontal tearing with syncrefresh on or off - no matter. I'm testing this in Viewpoint which is 320x224 @ 59.19. My native resolution is 190x1080 @ 60.
It's not nearly as bad without HLSL, but still there. Any way to get this setup work without tearing?
« Reply #3 on: June 25, 2013, 01:32:07 pm »
Make sure you're using 'video d3d' for your LCD. I'm testing Viewpoint here with GM 0.149 and it works perfectly smooth/no tearing.
Endprodukt
« Reply #4 on: June 25, 2013, 04:09:06 pm »
I'am using D3D. Here's my ini:
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  0
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   lcd
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x        0
hlsl_prescale_y        0
hlsl_preset           -1
hlsl_snap_width        1920
hlsl_snap_height       1440
shadow_mask_alpha      0.060
shadow_mask_x_count    320
shadow_mask_y_count    240
shadow_mask_usize      0.375000
shadow_mask_vsize      0.375000
curvature              0.04
pincushion             0.05
scanline_alpha         1.0
scanline_size          1.000000
scanline_height        1.00000
scanline_bright_scale  1.000000
scanline_bright_offset 0.000000
scanline_jitter        0.000000
defocus                0.00000, 0.00000
converge_x                0.2,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.2,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 0.85,0.15,0.0
grn_ratio                 -0.1,1.1,0.0
blu_ratio                 -0.075,0.0,1.075
saturation                1.00
offset                    -0.15,-0.18,-0.18
scale                     1.15,1.18,1.18
power                     1.0,0.8,0.7
floor                     0.0,0.0,0.0
phosphor_life             0.1,0.1,0.1
yiq_enable             0
yiq_cc                 3.600000
yiq_a                  0.500000
yiq_b                  0.500000
yiq_o                  0.000000
yiq_p                  1.000000
yiq_n                  1.000000
yiq_y                  6.000000
yiq_i                  1.200000
yiq_q                  0.600000
yiq_scan_time         52.600000
yiq_phase_count        2.000000
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.1
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
Using the standard HLSL settings didn't make a difference.  I'm using a different PNG now and a different post.fx. Changing those back to normal didn't change anything. Also, I couldn't make a screenshot of the tearing. It simply isn't in the screenshot?
« Reply #5 on: June 25, 2013, 04:51:11 pm »
May you post a log, I'm curious of what's going on there. What video card are you using?
« Reply #6 on: June 25, 2013, 05:19:34 pm »
Ok I think this issue is related to the one I explained here: http://forum.arcadecontrols.com/index.php/topic,128879.msg1367170.html#msg1367170
It's not really tearing, it's just a glitch due to scaling. However I can't make it disappear here by forcing lower -prescale values. It just stays whatever I do. This is when testing with an Intel card. Before I was testing with an ATI HD 6450 and it was flawless.
Interestingly this didn't happen in the previous intermediate version 0.148u5, so it must be something that has been modified in the middle.
Endprodukt
AW: What are the settings for GM to use with an LCD, HLSL, LCD-Setup?
« Reply #7 on: June 26, 2013, 04:00:06 am »
Okay, thanks. I'll try an older version.
Endprodukt
« Reply #8 on: June 26, 2013, 11:05:43 am »
Same problem with 0.148 u5. Maybe it's related to the graphic driver? Attached a log of viewpoint.
« Reply #9 on: June 26, 2013, 11:34:32 am »
Have you tried forcing -prescale to different values (1, 2, 3, etc.)? Do this from command line, not from the ini.
