Author Topic: Q*bert knocker question  (Read 1455 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: June 19, 2013, 09:51:28 am »
Hello, read a lot of threads about the Q*bert knocker.  So maybe there is a pinball person out there that knows of a coil that activates on 12V vs 27V.  I am actually trying to run a real Q*bert with an upgraded power supply that only puts out 12V to the knocker.  It's soft, but still activates on 12V.
Any easy solutions?
Thanks,
-SP
RandyT
    • GroovyGameGear.com
Re: Q*bert knocker question
« Reply #1 on: June 19, 2013, 11:00:09 am »
Find a small 24v power supply which puts out enough current for the knocker, run the 12v to the coil of a 12v relay, and the 24v going to the knocker can be controlled with it.  I indicated 24v, as these would be easier to find than 27v, and still get you close enough for a convincing "thwack".
southpaw13
  • Whatever!
« Reply #2 on: June 19, 2013, 07:18:46 pm »
Thanks!  Would it be possible to get a little diagram for the electronically challenged gamer?
Thanks,
-sp
whammoed
  • Last login:November 17, 2025, 11:13:27 am
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: June 21, 2013, 02:58:18 pm »
Most simple:  switch the coil out for: A-5194
This should give it the same oomph as normal but at 12v
see here:
http://forums.arcade-museum.com/showthread.php?p=1921796#post1921796
southpaw13
  • Whatever!
« Reply #4 on: June 22, 2013, 11:05:38 am »
Awesome!  I will try it!
