Author Topic: Silent JLW switches?  (Read 2624 times)
edekoning
« on: June 14, 2013, 02:47:30 am »
Many shops seem to carry silent switches for Sanwa JLF's and or Seimitsu LS-32's. But I never saw any silent switches for a Sanwa JLW. Does anybody know of a shop that sells silent switches for JLW's, or can I just use the JLF silent switches?
  • Last login:Yesterday at 05:41:43 pm
Re: Silent JLW switches?
« Reply #1 on: June 14, 2013, 11:23:15 am »
Well, unless the "JLF switches" are attached to a PCB, like the one that the JLF originally comes with, you should be able to use these switches, no problem.  :cheers:
mgb
  • North East, US
« Reply #2 on: June 14, 2013, 01:20:13 pm »
Both GGG and Paradise have soft switches for use with JLW.
Personally I like the cherry switches like used on happ supers. That what I use in my JLWs.
If you're talking about the optical switches for the JLF like the spark or flash1, then no I don't know of one for the JLW
« Reply #3 on: June 14, 2013, 01:32:23 pm »
The "soft" switches aren't the same as the "silent" Omron switches sold on fight stick sites.
According to the video, the model is Omron D2RV-G (they ain't cheap)
They are standard size and would work in a JLW, but you might have to disassemble them to add the levers or find a model with the same length levers already attached.  The ones from the fight stick sites won't include them.
I'm guessing that the guy in the video still has a pcb attached for the sake of spacing.
EDIT: Levered version is model D2RV-L (or LG for more force) http://www.mouser.com/ds/2/307/en-d2rv-12477.pdf
$15 each at Mouser.  :o
http://www.mouser.com/ProductDetail/Omron-Electronics/D2RV-L/?qs=sGAEpiMZZMumBvQ1hY%2ffBZLFyGKvjPOAoSpkH%2fLhBpA%3d
I see Paradise Arcade Shop is selling non-levered ones for $8
« Last Edit: June 14, 2013, 01:47:03 pm by BadMouth »
« Reply #4 on: June 15, 2013, 12:13:16 am »
Make JLW silent with GGG Versa Micro Switch's.
edekoning
« Reply #5 on: June 15, 2013, 04:39:22 am »
@badmouth
4 switches per stick * 2 sticks = way too much, damn those are expensive switches
@ond
Thanks for the pictures! I see those switches are about 2,50, so 10 per stick which is ok. I'll pick them up the next time I order from groovygamegear.
Just out of curiosity, but are all joysticks generally as loud as the JLW's?
« Last Edit: June 15, 2013, 11:46:29 am by edekoning »
mgb
  • North East, US
« Reply #6 on: June 15, 2013, 09:07:24 am »
Well I know both JLWs and JLFs are loud.
Cherry switches like found in happ and il sticks are barely audible once installed in a cp
And the soft switches from GGG really have no audible click.
« Last Edit: June 15, 2013, 09:11:03 am by mgb »
