Author Topic: Ultimarc MiniGrip Joystick rotate handle  (Read 2896 times)
GeoMan
  • Last login:December 16, 2025, 02:09:05 pm
« on: June 13, 2013, 03:12:58 pm »
Has anyone rotated the Ultimarc MiniGrip handle, to look like this?
If so, what needs to be removed to turn the handle 90o? Do i have to disassemble the handle?
  • Last login:Today at 01:48:21 am
Re: Ultimarc MiniGrip Joystick rotate handle
« Reply #1 on: June 13, 2013, 03:48:02 pm »
To change the orientation of the mounting plate from the long axis of the plate being on the X-axis to the Y-axis, just remove the 4 screws holding the mounting plate to the joystick base and turn it 90 degrees.
Your picture shows 3 of the 4 screws.
EDIT:  Also note that there are two tabs on the pivot that keep the stick from rotating.
« Last Edit: June 13, 2013, 04:04:10 pm by PL1 »
GeoMan
« Reply #2 on: June 13, 2013, 03:59:36 pm »
