Author Topic: DIY/Homebrew Pinball Scene?  (Read 8357 times)
Well Fed Games
  • Delicious!
« on: June 11, 2013, 09:19:46 pm »
OK, so I've got it in my head that I would love to build a a real mechanical pinball someday (at the rate of my projects, it may be a decade from now). Anyway, is there a "scene" for this, or a forum similar to BYOAC for that kind of projects? I've enjoyed what I have seen via Ben Heck and Jeri Elsworth but when I search I tend to run into virtual pin sites. Anyway, links, suggestions on search terms, etc. appreciated!
Re: DIY/Homebrew Pinball Scene?
« Reply #1 on: June 11, 2013, 09:32:04 pm »
Supposedly, Skillshot Pinball is a company that can provide most of what you need to build your own pin. They're new, and the info I've found is very little...
Skill Shot Pinball are creating a complete system to allow people to design and build their own pinball machines, supplying everything from the cabinet to the control system.
The Skill Shot Pinball driver board
They had a demonstration machine with the driver board controlling multi-colour LEDs below the playfield inserts.
Like you said, years down the road...
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #2 on: June 12, 2013, 06:15:53 am »
Check out t800's WOOLY thread over on vpforums. He has taken his virtual table and is turning it into a real pin. I recently cnc cut the Playfield for the project and also just sent him a wide body cabinet kit for it.
Pm me for custom cnc needs...
Well Fed Games
  • Delicious!
« Reply #3 on: June 12, 2013, 07:51:04 am »
Thank you both, I will check out those leads!   :cheers:
spoot
  • Destroyer of electronics
« Reply #4 on: June 12, 2013, 11:06:16 am »
There is these guys too.......some projects/code/etc in the forums.
http://www.pinballcontrollers.com/
TopJimmyCooks
« Reply #5 on: June 12, 2013, 12:59:51 pm »
If you want to do it easily, get a solid state pre dmd game with playfield features that you like, rearrange them on your newly Macattack cnc'd pf, and get a p-roc to run things and do your rules and scoring.  cut and extend the harness as necessary.  Print a vinyl overlay for the pf art.   Seems like donor game plus $1K of p-roc bits plus beater pc plus playfield plus artwork and you're in business.  could probably do a budget build for under $2500.
macattack
« Reply #6 on: June 12, 2013, 06:54:14 pm »
I have similar plans at some point.
Well Fed Games
  • Delicious!
« Reply #7 on: June 13, 2013, 10:23:10 am »
Yeah, I am keeping my eyes open for a donor. I would want a widebody so that may limit me a bit. The hard part is it is so much fun designing the thing in my mind/on paper I want to get started... then my arcade cabs remind me that they are in line first!
I get the feeling that the scene is going to boom pretty quick. When I see a project like t800's it is really inspiring... makes sense that physical tables would sprout out of virtual ones!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #8 on: June 13, 2013, 02:57:30 pm »
...makes sense that physical tables would sprout out of virtual ones!
I guess. Not to me....   Why a wide body?
-Banned-
Well Fed Games
  • Delicious!
« Reply #9 on: June 13, 2013, 03:10:49 pm »
Well, I mean, you've got these folks building virtual pin tables, learning angels and physics (or at least a close approximation). The knowledge is there, so I assume the challenge of building a physical pin cabinet might be attractive to some of the creators. Mostly a theory based on the Wrath of Olympus build.
Widebody, as the concept I am mulling over involves several inner playfields (possibly one under the main layer, like Black Hole). I think I will need the extra inches.
spoot
« Reply #10 on: June 13, 2013, 03:51:30 pm »
Looking at widebody as well to fit more stuff on my design.  Heck, I was even toying with rotating playfields but cost would start to be an issue.
Well Fed Games
  • Delicious!
« Reply #11 on: June 14, 2013, 05:06:43 pm »
Yeah, I haven't priced anything yet... I get the feeling that it is going to be really expensive!
ebarlow99
« Reply #12 on: June 27, 2013, 03:25:05 pm »
they are fun! here is mine
go here www.xtremepinball.com
tell him Bartop-Arcades sent ya! Greg does awesome work!!
« Last Edit: June 27, 2013, 03:27:37 pm by ebarlow99 »
MTPPC
« Reply #13 on: July 01, 2013, 11:44:15 am »
Are you running the dB2S backglass on that attack from mars setup? If so, you can set the backglass to 3 screen mode and lose the speakers and empty dmd space at the bottom of your second screen.
http://pinballmd.com/
ebarlow99
« Reply #14 on: July 02, 2013, 09:23:58 am »
ah thanks! will check it out.....to much to do so little time!!!  ;D
thanks!!
