Author Topic: i meesed up my crt via service menu, help!!!  (Read 1047 times)
sham69
  • Last login:June 12, 2015, 06:03:44 am
« on: June 10, 2013, 01:51:52 pm »
Hi,
My old crt blew so I had to get a new philips tc (second hand) to replace it.
When I plugged it in it looked pretty close to the old one but needed to be adjusted vertically and horizontally.
I did this easliy on the old set but seem to be having a problem with this one.
I adjust the vsh and hsh accordingly , needs a bit of tweaking here and there to get it just right.
Problem I am having is, the screen is now flashing every second like its trying to calibrate itself?
When I try to adjust the vsh again it re-adjusts itself.
I can get around it by setting it and quickly putting the tv in standby.
I think I also adjusted the options (op1-7) but not sure what the values were in there...
I have attached a screenshot.
Any advice greatly appreciated.
Its a philips silver 21 inch crt, I can get the model number if needed.
I accessed the service menu by entering 062596 and info on the remote.
Cheers.
Sham.
sham69
Re: i meesed up my crt via service menu, help!!!
« Reply #1 on: June 11, 2013, 04:14:37 pm »
figured it out.
thanks.
