Author Topic: Ipac2 Newb: Black Screen after button hit [SOLVED]  (Read 3699 times)
Kevinem82
  • Last login:July 25, 2013, 10:55:14 am
« on: June 08, 2013, 10:18:35 pm »
Update: Issue Resolved - Thanks to anyone who offered help and suggestions
I hook my Ipac2 up and start windows, launch hyperspin, hit the joystick and I get a black screen. I never had a problem while using a mouse and keyboard so I must have wired something wrong
« Last Edit: June 10, 2013, 10:55:50 am by HaRuMaN »
Kevinem82
Close Thread
« Reply #1 on: June 08, 2013, 11:46:09 pm »
update: issue resolved
someone please, after hyperspin loads up and I hit a button, i get a black screen, this didn't happen when I was using a mouse or keyboard.....what am i doing wrong  :dunno
« Last Edit: June 09, 2013, 10:54:46 pm by Kevinem82 »
Re: Ipac2 Newb: Black Screen after button hit
« Reply #2 on: June 09, 2013, 12:17:43 am »
you didn't map the keys to the stick directions something weird did you?
heard a guy once, he said that if you pressed these 2 particular buttons at the same time the game would disappaer to the menubar. turned out he'd mapped the 2 buttons to ALT and TAB  :laugh2:
Kevinem82
« Reply #3 on: June 09, 2013, 12:59:12 am »
i didnt map anything. I load hyperspin, hit any button and i get a black screen  :hissy:
« Reply #4 on: June 09, 2013, 01:05:08 am »
ps2 or usb?
some people have experienced issues with using USB, but have none with the PS2 connection.
Kevinem82
« Reply #5 on: June 09, 2013, 01:25:13 am »
ps2 to usb. Would it have anything to do with insta-sheller? I can't pinpoint what is causing this....hyperspin, insta-sheller, ipac....oooo so frustrating  :banghead:
I'm so close to completing my cab
BobA
  • What Me Worry?
« Reply #6 on: June 09, 2013, 04:05:53 am »
Did you go thru the standard work in the proper order?
Get the emulator working
Get the emulator working in HS
Add Shell or other enhancements
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #7 on: June 09, 2013, 11:55:56 am »
I receive many support emails from people using Hyperspin. All kinds of different random issues. Owing to the volume of issues with this front end and also that I have not used it myself so have no in-depth experience of it I have had to adopt a policy of asking people to try another front end. This always seems to work.
I realise this is not very helpful but I am convinced there are hidden issues with Hyperspin and multiple keyboard or game controller devices.
« Reply #8 on: June 09, 2013, 01:15:53 pm »
load up notepad and see if the keystrokes are getting through.
if they are it's a software issue not the ipac hardware.
EMDB
  • Project RetroCade
« Reply #9 on: June 09, 2013, 02:59:15 pm »
iPac2 with Hyperspin works fine for me.
Did you try the WinIPAC application (http://ultimarc.com/download.html) to verify the iPac is correctly wired (and functioning) before blaming HyperSpin?
Chris John Hunter
« Reply #10 on: June 09, 2013, 06:50:34 pm »
Just get a better front end or BUILD YOUR OWN FRONT END. Cough.
Chris John Hunter
« Reply #11 on: June 09, 2013, 06:54:08 pm »
I think you have a point here.
But I would ask one question, if the controller is showing in control panel, game controllers and its been tested working functioning. Surely any Front End can register the joystick/buttons and  will work with it ? Am I missing something ? I got so annoyed with HS I wrote my own front end and am currently showing others how to do the same on another thread, Software section if your interested.
Chris John Hunter
« Reply #12 on: June 09, 2013, 06:56:01 pm »
I know this is off point here, but can I take a moment to say Hyperspin would be great if it wasn't for the way it lists every game ever on the mame list. And it is a right sod to edit.
Kevinem82
« Reply #13 on: June 09, 2013, 10:53:52 pm »
issue found. it was a ground problem on my happ coin door
close thread thanks to anyone who posted suggestions
« Reply #14 on: June 10, 2013, 10:23:59 am »
A lot of them probably downloaded it already set up expecting it to be plug 'n play and have no clue how to use it.
  • Last login:Yesterday at 06:20:48 pm
Re: Close Thread
« Reply #15 on: June 10, 2013, 10:45:43 am »
Suggestion- rename this thread to the original title, with [SOLVED] at the end. Changing the title to "Close Thread" doesn't really do anyone any good. At least with the original title, someone with a similar issue could be helped.  :cheers:
« Reply #16 on: June 10, 2013, 12:07:54 pm »
wierd. the bad ground must have been causing a feedback of some kind through your computer system when a button was activated.
