Author Topic: Cruis'n USA steering Question  (Read 4454 times)
eclipso
  • Last login:August 21, 2018, 08:51:25 am
« on: June 08, 2013, 02:22:24 pm »
So I picked up a USA sitdown for 100$, got what I paid for, in good shape no monitor or board but rotating the steering wheel its not smooth, its like I can feel the gears "clicking" when it rotates and if my memory is right it was / should be a smooth rotation left to right and vise versa. That being said Im not sure if thats a fixable issue, I havnt taken it apart yet but there is one on ebay for sale that claims it works but I wanted some education on it before I comit to possibly bidding on it or not. thanks guys.
mgb
  • North East, US
« Reply #1 on: June 08, 2013, 02:56:45 pm »
Everything is fixable.
First step would be to open the control panel and start testing.
  There is gearing in these panels.
Pick up a manual so you have better info on what needs to be lubed and adjusted and where.
There are a lot of sources for PDF manuals.
Here's a good one:
http://arcarc.xmission.com/
There's a place I have gotten parts from in the past. They carry a lot of stuff like gears that may be needed for your cab.
It's something like videogameparts.com or something like that.
  • Last login:December 13, 2025, 11:44:57 pm
Re: Cruis'n USA steering Question
« Reply #2 on: June 08, 2013, 03:59:31 pm »
This is just a random guess, but if it's clicking when you move the wheel then something is probably wrong with the gears.  They might just need greased.
You are going to have to take the control panel apart and identify what is making the clicking noise before we can tell you anything.
  • Last login:December 10, 2025, 07:49:38 am
« Reply #3 on: June 08, 2013, 04:44:43 pm »
If it's a standard Happ FFB setup (which IIRC it should be if original), then there aren't any gears.
The potentiometer is attached directly to the end of the shaft.  There is a timing belt style pulley that links it to the ffb motor.
The bearings are large enough I doubt they'd go bad, but I'm not an arcade tech.
More likely it is something to do with the belt or the ffb.
You'll just have to get in there and see.
eclipso
« Reply #4 on: June 08, 2013, 08:15:26 pm »
yea this is how its set up, ill pull it out tomorrow and get some more information, I spend free time today sanding and painting the seat assembly, it was rusty but looks good now.
Mattroid
  • Last login:December 28, 2013, 07:37:31 pm
    • Arcade Crusade
« Reply #5 on: July 05, 2013, 08:03:50 pm »
Just curious if there's an update on this or not. I'm in the middle of troubleshooting a similar issue with my Cruis'n USA.
