Author Topic: Need some help with JoyToKey  (Read 3670 times)
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« on: November 12, 2003, 05:41:50 pm »
I could use some help with JoyToKey.  I need to use it so that I can use MameWah(I did a gamepad hack).  Anyways, If I hold the joystick going one way and then stop pushing it that way, it acts like I'm still pushing it for a second or so.  It's really annoying.  Buttons don't always register either.  Should I just get another frontend and forget about using JoyToKey?  Is there a setting I'm missing?(in either mame or JoyToKey)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
Re:Need some help with JoyToKey
« Reply #1 on: November 12, 2003, 06:30:21 pm »
what kinda of joypad are you using? I used the old school Sidewinders and they work great!
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #2 on: November 12, 2003, 06:44:44 pm »
I had the same problem with a playstation joystick I was using with an PSX-USB adapter, but it happened without JoyToKey as well. I'm using JoyToKey now with a pair of USB gamepads without any trouble.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #3 on: November 12, 2003, 07:01:38 pm »
I did a little testing and was able to reproduce your problem. I think it you adjust your "threshold for input" under the "others" tab it may fix your problem. I have mine set to 50% if I set it to 0% (default I believe) I get the same problem.
Hope this helps!  ;D
All Your Base Are Belong To Us!
IceCold
« Reply #4 on: November 13, 2003, 06:22:45 pm »
Hope this helps!  ;D
About to go try it, it's currently set at 0%.  Thanks for the tip!
To everybody else, I was using Gravis Gamepad Pro's(gameport version) and they worked just fine before without JoyToKey.
I'll respond after I've tested it.
Spaced Invader
« Reply #5 on: November 15, 2003, 08:17:00 am »
Just to satisfy my curiosity, did that fix it?
IceCold
« Reply #6 on: November 15, 2003, 11:23:58 am »
No, it seems like it may have helped a little, but it's still funky.  :(
Spaced Invader
« Reply #7 on: November 16, 2003, 08:23:38 am »
I really don't know. The only other thing that comes to mind is adjusting your "automatic shooting" setting. Good luck...sorry I couldn't help more.
