January 25, 2026, 07:09:39 am
For your budget, it seems like a good fit.
Okay, decided I didnt want to go with an APU so-AMD Phenom X4 Black Edition 3.4 Ghz (plan to Overclock to 3.8 eventually if needed)4GB 1600 Mhz RamEVGA 1 GB GDDR5 GeForce GTX 460 Video CardA750-1010 ::ARCTIC Freezer A30 CPU Cooler - For AMDE436-500F12 ::ENYLE 500W ATX Power SupplyBiostar A780L3C AMD 760G/SB710 Motherboard - MicroATX, Socket AM3So, should this be enough. I figured if the x3 3.4, could run most of it, an X4 should be an extra boost and can overclock if needed and I believe the GTX 460 is more powerful, so should this be good enough of a rig?
To be honest, I'd lean going towards AMD's newer APU's. As much as I like Intel, AMD's newer APU's are really hard to argue with, especially in your situation. I'd go for the AMD APU build, with the idea that you can pair it up with an AMD card down the road if you need to.
