Author Topic: Kortek KT1948 No H-Size Adjustment  (Read 2746 times)
Brian74
  • Yep... I built that!!
« on: June 06, 2013, 09:58:16 pm »
I have a 19"  Kortek KT1948. I am a noob when it comes to arcade monitors. My image is way to big for the screen. All the other adjustments on the remote control work. If I turn the h-size knob, I see very little movement. Does that mean I have bad caps? If so, how do I use a multi-meter to test them? Which ones?
  • Last login:January 26, 2026, 07:56:08 pm
Re: Kortek KT1948 No H-Size Adjustment
« Reply #1 on: June 07, 2013, 03:14:21 pm »
bad caps - probably
multi-meter to test them? - no, you need a special meter to test capacitors properly...
this monitor is several years old now. it's best to just replace the electrolytic capacitors and go from there. there are some capacitors that the monitor uses to time how long to scan a line on the screen by how long it takes for the capacitor to charge up and discharge. tweaking the horizontal size adjusts the voltage going in to that capacitor. when the cap gets old, it doesn't hold as much charge as before and thus, discharges quickly as a result. this throws the timing off, making the scan very wide.
I can't tell you specifically which one it is with this chassis, but all the caps are old and dried out and not at their best anymore. it's best to change them out.
Brian74
« Reply #2 on: June 07, 2013, 04:36:16 pm »
I don't have the knowhow, or the tools. Who do ppl use to replace caps?
Sent from my SGH-T989 using Tapatalk 2
MonMotha
« Reply #3 on: June 07, 2013, 04:45:08 pm »
Most people do it themselves.  It's not too hard once you get the hang of it.
If you do want to have somebody do it for you, you've got a couple choices: you can take the whole monitor to a local TV repair shop (if you can find one) and get charged ~$100-150, or you can pull the chassis board (often the hardest part of the process, mind you) and ship it off to an enthusiast who will maybe do it for $25-50 + parts and return shipping.
Brian74
« Reply #4 on: June 07, 2013, 04:53:39 pm »
I guess I could probably pull the chassis. Take lots of pics of it before I pull it so I know how it goes back together. Now to find someone to do it ::)
