Author Topic: Reverting to 31khz mode  (Read 3013 times)
lordsnipe
  • Last login:August 30, 2014, 11:49:06 pm
« on: June 05, 2013, 08:41:29 pm »
Hey Calamity and others,
Haven't found any way to do this yet, but is there a way after vmmaker has been run to revert back to 31khz mode? For example, say pulling the PC out and doing some configs away from the 15khz monitor...?
I think safe mode could work but then other drivers aren't loaded either .. is there a command within VMMaker to revert back?
Calamity
  • Moderator
  • Last login:Today at 03:33:24 am
  • Quote me with care
Re: Reverting to 31khz mode
« Reply #1 on: June 09, 2013, 09:59:34 am »
Hi lordsnipe,
There's nothing to revert here. You have both 15 kHz and 31 kHz resolutions (just to simplify, because you have also 48 kHz and higher), It's just a matter of picking the right resolution for the desktop depending on the monitor you want to target.
Steps to create a log:
lordsnipe
« Reply #2 on: June 29, 2013, 09:02:34 am »
Hey Calamity,
If I have run vmmaker with the default 15khz values then what do I need to do to switch to a 31khz 640x480 so I can service a machine on a bench with a pc monitor?
I looked through ArcadeOSD and also through display settings and couldn't find much.
Cheers.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #3 on: June 29, 2013, 09:28:59 am »
you should just need to go into your adapter settings and change it.. that resolution is available to you..
Calamity
  • Moderator
« Reply #4 on: June 29, 2013, 10:09:11 am »
Hi lordsnipe,
Does it necessarily have to be 640x480? Why don't you try 800x600 or even 1024x768? Those will probably be at their native frequency and definitely a better choice for servicing a machine.
If the monitor you're going to use for servicing is a LCD, why not using its native res?
640x480 31kHz is overridden by the default 15kHz interlaced mode that's installed with the drivers.
lordsnipe
« Reply #5 on: June 30, 2013, 07:34:28 am »
Using ArcadeOSD, I didn't see a 800x600 or 1024x768 option. Did what I needed to do though by uninstalling the driver and using the generic vga one.
