Author Topic: Are these 2 bugs fixed in the latest builds?  (Read 2365 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« on: May 31, 2013, 05:31:44 am »
First, at least in full screen low res mode, the first time you launch a game, after the loading screen, the layout appears on screen for a moment before MAME is loaded. A workaround for this is a script that loads MAME hidden and quits it inmediatly. This is what I'm using, but it means some additional seconds of delay in my boot process.
Second, after switching orientation, if you're in the top position of the gamelist, the first game doesn't show its snapshot. My solution is to to add a name called 0000 with no data to mame.xml and with black snapshots, so it will be the first game. It's not perfect but I prefer a blank space than a game without snapshot.
I would try it myself, but the download page is not working.
« Last Edit: May 31, 2013, 06:02:59 am by Stormrider »
Stormrider
Re: Are these 2 bugs fixed in the latest builds?
« Reply #1 on: May 31, 2013, 05:25:46 pm »
I've just download and tried the latest version of MaLa and the first problem is still there. Once you have run the first game, it's gone anyway. The second issue, however, doesn't happen now. That's nice!
