Author Topic: VMMaker kills my Hyperspin  (Read 1944 times)
josh303
  • Last login:August 06, 2013, 01:23:13 am
« on: May 22, 2013, 06:32:18 pm »
Hi Guys, first post here.
Hey All
Just finishing off a DIY build here, i've got a Samsung 29" CRT and I am using the CRT Emu drivers. I've been launching Hyperspin fine, but the issue is when I exit a game is screws up my CRT. I've tested a few other FrontEnds and they all do the same thing. If I run games straight through Mame then startup and exit just fine.
I've got WinXP 64b as my OS, and I'm using GroovyMame (0147u3.014) with HyperSpin 1.3
I set the Arcade OSD to 640x480, and the CRT is just cabled to my VGA card, it's a Radeon x300. The chassis is a Wei-Ya M3129D01-7.
Typically it happens with older games, like Galaga, 1942, etc. Seems switching back to Hyperspin resolution is causing me to lose sync.
I'll post my vmmaker and mame ini files here next.
josh303
Re: VMMaker kills my Hyperspin
« Reply #1 on: May 22, 2013, 06:39:13 pm »
VMMaker.ini:
; VideoModeMaker - Options
; 1. MAME
; Path for Mame executable, in case we want to extract xml information from it.
MameExe = "C:\Arcade\GrooveyMAME\mame.exe"
; Path for Mame ini folder, in case we want to create an ini file for each game.
; Important: existing ini files will be overwritten.
IniPath = "C:\Arcade\GrooveyMAME\"
; Mame options.
ListFromXML = 1 ; Processes Mame XML and get video mode list from it
GenerateXML = 1 ; Extracts XML from Mame (only needed once)
OnlyListMain = 0 ; Only list resolutions for games contained in MameMain.txt
GenerateInis = 0 ; Creates an ini file for each Mame game, in the IniPath folder
SDLMame = 0 ; Use SDLMame specific options
; Monitor orientation
MonitorHorizontal = 1 ; 0 = Rotating monitor: horizontal and vertical games at their native resolution
; Suitable for users that physically rotate their CRTs
; 1 = Horizontal monitor: horizontal games run at their native resolution and
; vertical games are rotated to fit in horizontal monitor
RotatingDesktop = 0 ; Specifies if both desktop and monitor are rotated
; Aspect ratio for vertical games on horizontal monitor
; 4:3 (keeps original aspect ratio)
; 3:3 (stretches to square format)
; 3:4 (stretches to full screen)
; h:v (custom aspect ratio)
VerticalAspect = "4:3"
; 2. MONITOR
; Monitor Type. Valid types: D9800, D9400, D9200, EGA, VGA, MULTI, H9110, PAL, NTSC, GENERIC, CUSTOM
MonitorType = "CUSTOM"
; Monitor CUSTOM. These values will be used if MonitorType = "CUSTOM"
; monitor_specs0-6 HfreqMin-HfreqMax, VfreqMin,VfreqMax, HFrontPorch, HSyncPulse, HBackPorch, VfrontPorch, VSyncPulse, VBackPorch, HSyncPol, VSyncPol, ActiveLinesLimit, VirtualLinesLimit
; * HfreqMin-HfreqMax: Minimum and maximum horizontal frequency, in Hz. Defines the range of horizontal frequencies the monitor is capable to sync.
; The higher the horizontal frequency, the higher the vertical resolution available for the same vertical refresh.
; The higher the horizontal frequency, the higher the vertical refresh available for the same vertical resolution.
; The higher the horizontal frequency, the lower the horizontal amplitude of active video (narrower picture).
; * VFreqMin-VfreqMax: Minimum and maximum vertical frequency, in Hz, Defines the range of vertical frequencies the monitor is capable to sync.
; * HFrontPorch, HSyncPulse, HBackPorch: Horizontal timing and geometry, values in µs
; * VfrontPorch, VSyncPulse, VBackPorch: Vertical timing and geometry, values in ms
; * HSyncPol,VSyncPol: sync polarities, 0 = negative, 1 = positive.
; * ActiveLinesLimit: Vertical resolutions until ActiveLinesLimit value included, are generated as progressive, regardless the possibility
; of obtaining the required vertical refresh value.
; * VirtualLinesLimit: Vertical resolutions above ActiveLinesLimit and below VirtualLinesLimit are virtualized, that is, an interlaced resolution
; bigger that the native one is generated, with the right refresh, and "hardware stretch" is applied.
; Vertical resolutions above VirtulaLinesLimit are generated as interlaced, without any stretching.
monitor_specs0 15250-16500, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 288, 448
monitor_specs1 23900-24420, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 768
monitor_specs2 31000-32000, 40-80, 0.636, 3.813, 1.906, 0.318, 0.064, 1.048, 0, 0, 576, 768
monitor_specs3 37000-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 600, 768
; Tolerance for horizontal frequency, in kHz, enables extending the range defined by [ HfreqMin, HfreqMax ]
; The resulting allowed frequency range will be [ HfreqMin - HfreqTolerance, HfreqMax + HfreqTolerance ]
HfreqTolerance = 0.010
; 3. MODELINE GENERATOR
; Total number of modelines to generate. Here are the recommended values for each driver version:
; CRT_Emudriver, based on Catalyst 6.5: 160 modes (accepts up to 200, but above 160 HyperSpin will refuse to load)
; CRT_Emudriver, based on Catalyst 9.3: 120 modes (accepts some more but above 120 you can get some blue screens)
; Regular Catalyst : 60 modes (won't accept any more)
TotalModes = 120
; If enabled, only creates modes with 32 bits per pixel color depth
Only32BPPModes = 0
; Method for mode table generation. If Mame xml is processed, that will create a lot of different video modes, so the mode table
; will be optimized keeping the most relevant ones, and dropping the rest, to keep below the TotalModes value.
; 0 = Static table: modelines are generated keeping their original vertical refresh. This method is intended to be used in
; combination with ini files for each game.
; 1 = Dynamic table: a table of dummy modes is created using xres and yres values while ignoring vfreq. This method is intended
; to be used in combination with Switchres or Groovymame. No ini files are required using this method (you should disable the
; GenerateInis option).
; 2 = Magic table: a table of 'magic resolutions' is created, by ignoring xres and vfreq and just keeping yres. This method greatly reduces
; the total number of modes in the list. It's only supported by GroovyMAME, and is intended as a workaround for the Hyperspin issue.
ModeTableMethod_Custom = 0
ModeTableMethod_XML = 2
; Minimum resolution values (these will be used instead of lower values)
XresMin_XML = 240
YresMin_XML = 224
YresRound_XML = 4
XresMin_Custom = 240
YresMin_Custom = 160
YresRound_Custom = 0
; Minimum dotclock value allowed by the video card, in MHz (i.e. DotClockMin = 7.010)
DotClockMin = 0
; Number of iterations used by the mode generator [0,5]. The higher the number of iterations, the bigger the accuracy of the vertical
; refreshed obtained, normally at the cost of increasing the horizontal frequency strictly required.
Iterations = 0
; Specifies if the refresh label is multiplied by 10 before rounding (experimental).
VFreqLabelx10 = 0
; 4. DRIVER
; Path for the driver folder
DriverPath = "C:\Arcade\driver\"
; If UpdateRegistry is enabled, UpdateDriver will only work if the driver version found in DriverPath matches the one installed
; in the system.
UpdateRegistry = 1 ; Specifies if the video card registry section will be updated with the new video modes
; (will only work in combination with CRT_EMUDriver).
UpdateDriver = 0 ; Specifies if the driver files in DriverPath will be updated with the new video modes, for
; future installations.
AnyCatalyst = 0 ; Allows modelines to be installed for any Catalyst version. This option is experimental and
; known to produce some problems.
Mame.ini
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath C:\Arcade\Hyperspin\Emulators\Mame\Roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath .;ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
hiscore_directory hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
syncrefresh 0
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 1
use_backdrops 0
use_overlays 0
use_bezels 0
use_cpanels 0
use_marquees 0
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 1
uifont default
ramsize
confirm_quit 0
ui_mouse 0
# CORE MKChamp OPTIONS
disable_hiscore_patch 0
disable_nagscreen_patch 0
disable_loading_patch 1
# CORE SWITCHRES OPTIONS
modeline 1
monitor arcade_15_25_31
orientation horizontal
connector auto
interlace 1
doublescan 1
cleanstretch 0
changeres 1
powerstrip 0
lock_system_modes 1
lock_unsupported_modes 1
refresh_dont_care 0
dotclock_min 0
sync_refresh_tolerance 2.0
frame_delay 0
lcd_range auto
crt_range0 auto
crt_range1 auto
crt_range2 auto
crt_range3 auto
crt_range4 auto
crt_range5 auto
crt_range6 auto
crt_range7 auto
crt_range8 auto
crt_range9 auto
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 1
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 0
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion 9
filter 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# VECTOR POST-PROCESSING OPTIONS
vector_time_scale 0.0
vector_time_period 0.1
vector_length_scale 0.9
vector_length_ratio 4.0
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 1
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
dual_lightgun 0
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 23, 2013, 01:18:03 am »
You may want to post this in the groovymame forum where it will get more attention.
