Author Topic: AimTrak recoil header  (Read 1370 times)
stigzler
    • Mago Arcade
« on: May 22, 2013, 02:36:28 pm »
Hi folks. Just finished my first AimTrak lightgun hack on a £5 light gun:
http://www.ebay.co.uk/itm/Logic-3-Light-Gun-Sony-Playstation-1-2-PS2-PS1-Includes-Foot-Pedal-Gcon-Adaptor-/360612646318?pt=UK_CamerasPhoto_Printers_Printers_JN&hash=item53f6304dae
Fiddly, took a day and got solder head, but on the whole, went well! Now have LCD working lightgun, with 4 other buttons assignable as well :)
Got another to set up, so gonna take some proper pics this time + post a how-to guide. Rough Pic of hack:
https://docs.google.com/file/d/0B1BknYzq4cLvWlZGX0l5XzhzaXM/edit?usp=sharing
Two ideas sprang to mind and would like to try on my next attempt:
1. The header has a pin called "recoil." What I understand is that this sends a pulse when trigger is pulled. However, don't know what voltage nor for how long. My idea is this: place rumble unit of a DualShock controller into handle of gun and then wire up this recoil pin - anyone know if this'll work? Think it's proper purpose is to control a relay which controls a solenoid.
2, Laser sights at the bottom of the gun!! :)  - Anyone know what voltage these units are? Tried hooking it up to 5V and 12V supply - no lazer :( Would love to get this hooked up via one of the switches on the side of the gun :) but guessing can only get 5V supply from AimTrak module.
Deeper and deeper into the heart of darkness... lol
Steve
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: AimTrak recoil header
« Reply #1 on: May 24, 2013, 08:32:27 am »
The recoil pin outputs a 5 volt pulse which varies depending on the recoil setting in the config utility, up to a max of 40 milliseconds. To power any device would need a MOSFET for driving the necessary current.
Our recoil kit contains a replacement trigger PCB which has a MOSFET on it.
Andy
stigzler
    • Mago Arcade
« Reply #2 on: May 25, 2013, 05:03:50 pm »
Thanks ANdy - love the aimtrak. :)
lettuce
  • Make It So!
« Reply #3 on: May 25, 2013, 08:35:36 pm »
Andy do you sell the guns with the recoil and aimtrak pre-installed? How many buttons does your guns come with?
