Author Topic: Augh! Help! How do I unlock these locks?  (Read 2668 times)
dpdelcollo
  • Last login:February 17, 2004, 11:06:39 pm
« on: November 11, 2003, 01:24:25 pm »
I bought 6 video games yesterday.  some of them work, some of them don't.  all of them have the fronts unlocked, but only a few of them have the backs unlocked.  The guy had a few keys for some fronts, but no backs, and had no idea where they had gone.
Whats the easest way to get at these backs and work on them?  several of them are the kryptonite circular key type ones that I dont know how to get past.
Im tempted to just cut the door and make a new one, but am under pretty tight time pressure to get these games fixed and back out to the world.
Does anyone have any advice?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re:Augh! Help! How do I unlock these locks?
« Reply #1 on: November 11, 2003, 01:34:35 pm »
Drill the locks and replace them.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #2 on: November 11, 2003, 02:10:10 pm »
when i bought my used cab to work on, the guy didnt give me a key for the back lock, and it was just a regular one.  i tried drilling it but maybe my drill sucked or something cuz it didnt work.  by some crazy chance, one of my distant relatives was coming over from kentucky to pick up something for like 5 min.  well he happens to be a police officer and he got a bobby pin and picked the lock for me.  so if you can get a bobby pin, you can try to tinker with that.
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #3 on: November 11, 2003, 02:33:59 pm »
You can bring a lock smith in, it might be cheaper to pay him to pick the locks than to replace the doors.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #4 on: November 11, 2003, 02:34:32 pm »
http://home.howstuffworks.com/lock-picking.htm
Here is a good article on lock picking.  It's a useful skill and it's surprisingly easy on most small cabinet locks.  You don't have to have any developed skill if you just use the clumsy raking method.  Just rake the tumblers for five minutes to half an hour and your bound to get it open.
Anyway, read the article even if you don't have any locks to pick cos it's really interesting just to see how a pin and tumbler lock works.
Best Kid iPad Apps
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
« Reply #5 on: November 11, 2003, 03:09:41 pm »
it is an interesting article. i remember looking at something similiar a while ago.
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #6 on: November 11, 2003, 04:55:44 pm »
Good luck picking a round key lock without the proper tools. Unlike a flat key lock, you'll have to successfully pick it seven or eight times to open it. Drilling them is a pain as well, though that is a viable option.
What I'd try first is to go in through the cab's front. Pop open the control panel, remove the bezel and monitor, and you'll be able to get at the back of the lock. Remove the lock's tab and the back panel will practically fall out.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: November 11, 2003, 07:25:42 pm »
What games are they? Are they original or conversion cabinets?
Here are the common back door key #'s for original games:
Midway 1350, 1355, MW350
Stern L-355
Nintendo K-6510
shmokes
    • Jake Moses
« Reply #8 on: November 13, 2003, 12:51:18 pm »
Most cabinet locks are flat key locks.  I have no idea how to pick round key locks.
Best Kid iPad Apps
SoooPig
  • Last login:July 02, 2004, 07:40:06 pm
  • Wooohoo!
« Reply #9 on: November 13, 2003, 03:19:55 pm »
Most these locks have a lock bar that is held on by a nut.  If you can get in the coin door, then you can usually reach the back side of the lock and remove this nut.  Sometimes you might have to remove the control panel to get back there, or even remove the monitor... but...
You can do it without destroying the lock, cabinet, or paying for a locksmith.  (You might have to pay for a contortionist tho)  ;)
hubster
  • Last login:August 18, 2003, 11:33:27 am
« Reply #10 on: November 13, 2003, 03:55:52 pm »
Try a screwdriver first.  Place it in the lock and turn. Sometimes you can move the whole locking mech 1/4 turn which is far enough to open the door.  The nut on the back of those locks are hard to keep tight.
dpdelcollo
« Reply #11 on: November 13, 2003, 09:23:51 pm »
actually ive had some strange luck with them so far.  My garage is packed so tight that I can only get to one of the games at a time and ahve to shuffle them around to do so, but the one with the cylindical lock I disovered that it is actually unlocked, and had been screwed closed with a screw.  With that gone, its open and I can replace it.
Some of the others are regular blade tumblers, and might be picked or tackled from the inside like some of the suggestions.  I really appreciate all the help.
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
« Reply #12 on: November 13, 2003, 10:33:46 pm »
This works! Save some hassle and get a big f***ing screwdriver and give it a mighty twist!
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
APFelon
  • Last login:January 11, 2026, 06:54:36 pm
« Reply #13 on: November 13, 2003, 10:56:35 pm »
There are very few locks that can withstand a drill. Sometimes you have to be patient.
APf
dpdelcollo
« Reply #14 on: November 14, 2003, 01:51:13 am »
The screwdriver trick worked on one of the 4 remaining locks, and I was able to dissassemble another one from the inside.  only two remain, Zaxxon and Gorf!  woot!
