Author Topic: Ultimarc Aimtrak LED bars?  (Read 1726 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: May 05, 2013, 02:35:32 pm »
I'm going to order 2 aimtrak lightguns, in the instructions it says to put the LED bar centre top of the monitor, am I right in thinking I can use 2 guns with 1 LED bar ?
otherwise where do I mount the 2nd LED bar? on top of each other ?
At the moment I have 2 joysticks, 22 buttons ( I think ), 1 spinner and 1 trackball all needing to be set-up in all my emus and hyperspin, I'm hoping these guns wont cause any conflicts with the other controls as they're plug n play usb and will just override anything else when used, is this correct?
chopperthedog
  • Last login:Today at 07:06:13 am
Re: Ultimarc Aimtrak LED bars?
« Reply #1 on: May 05, 2013, 02:46:23 pm »
Only one bar is needed for up to four guns. You might find that unplugging after setup in mame and replugging may lead to having to reset the analog controls configuration again.
good day.
Connorsdad
« Reply #2 on: May 05, 2013, 03:27:09 pm »
good day.
Thank you :)
They will remain plugged in so no worries :)
