Author Topic: crane/claw machine help  (Read 2958 times)
jasonl2972
  • Last login:July 15, 2015, 12:26:14 am
« on: May 01, 2013, 10:30:55 pm »
Hi all,
   Recently picked up a claw machine and for the most part have it all running.My problem is i don't know who made the machine and this makes it hard to look up parts i need to complete the repair.The main parts i need are the drive belts on each end.One appears to go around 3 pulleys and the other around just 2.In the pics you can also see the lock that was used on the front sliding panels.I don't know what kind of lock this is called and haven't found another like it.It goes through a hole on each panel of glass and locks them together.The whole lock comes out with the key and allows the panels to slide.This in turn also allows you to reach through the prize drop chanel and unlock the control panel so it can fold down.I hope someone can identify it from the boards and maybe point me in the right direction so i can learn the claw settings and dip switchs and be able to find someone that sells replacement belts and parts.
Games I own. -Neo Geo 4 slot-Sega Turbo Outrun-Space Gun-Sega Hang on-World Series Baseball-Q-bert-V Ball-Magic Sword-Asteroids-Namco sticker club-Touch master 7000-Claw machine-Slot machine
jasonl2972
Re: crane/claw machine help
« Reply #1 on: May 01, 2013, 10:33:45 pm »
more pics
jasonl2972
« Reply #2 on: May 01, 2013, 10:36:26 pm »
And the pic of the lock in question
DLinkOZ
  • Last login:March 22, 2017, 08:12:46 am
    • The DaveCade
« Reply #3 on: May 02, 2013, 01:28:16 am »
I was able to get the "drive belts" from a large o-ring selection at my local non-big-chain hardware store.  They had a big bin with all sorts of sizes.
DLinkOZ
    • The DaveCade
« Reply #4 on: May 02, 2013, 01:41:17 am »
And the construction and coin mechs definitely scream Grayhound, to me.  So I'm thinking Grayhound Jumbo Skill Crane is what you have, though I could be wrong.
jasonl2972
« Reply #5 on: May 03, 2013, 06:31:56 pm »
i'm going to try the "o ring" suggestion at my local hardware store this weekend.I took a look at some greyhound machines but haven't found anything with similiar board sets so i'm not sure if thats the brand or not.The dip switch settings they had for greyhound machines didn't really match up as i only have the one set of switchs and they often talk about 2 sets.I might just have an older model or it maybe a different brand.
jasonl2972
« Reply #6 on: May 08, 2013, 06:18:02 pm »
My local true value was able to hook me up with some o rings and 2 sets of vacuum cleaner belts.To my surprise the vaccum belts were a perfect fit and the crane is working great now.Still no idea about the lock as every place i go and show it to has never seen one like it and can't even point me in a direction to look on the web.Also still need to figure out the claw strength settings and the dip switch settings on the board.
  • Last login:Yesterday at 12:40:25 pm
« Reply #7 on: May 24, 2013, 02:30:36 pm »
that lock looks like it belongs to some kind of "T-handle lock". if it goes through the glass you might have to try to source which it is. does it have any markings on it?
ed12
« Reply #8 on: May 24, 2013, 03:54:08 pm »
sorry bud
but that is a straight cabinet lock
drill it
replace it
just size the length and barrel
away u go
ed
