Author Topic: Polyurethane glue is the bomb!  (Read 1574 times)
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
« on: November 10, 2003, 10:50:45 pm »
You know, like Gorilla Glue or the elmers glue with a giant minotaur on the front.
That stuff has some holding power that is unreal. It takes a while (30 mins or so) to set up, but when it does, look out!
Also, it foams up. Less that Great Stuff
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
  • Last login:December 02, 2025, 03:23:14 pm
Re:Polyurethane glue is the bomb!
« Reply #1 on: November 10, 2003, 11:03:09 pm »
Yes, but does it taste good?
cj1
  • Last login:January 16, 2007, 03:47:57 pm
« Reply #2 on: November 10, 2003, 11:18:03 pm »
No, but it is less filling.
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #3 on: November 10, 2003, 11:42:17 pm »
"He said Guerilla not Gorilla! Go! Gur! Huge difference! Huge difference!"
They make that stuff out of Gorillas?  I never knew Gorilla foamed up like that...
Okay, in all seriousness, I don't agree with using Ployurethane glue.  It causes more headaches because it foams up and it is harder to work with.  If you don't get it off your hands, as you said, you'll be carrying it around for at least a day.
Ployurethane glue is great for projects that will be exposed to moisture.  Our cabs are hardly going to be subjected to moisture (or else we wouldn't use particle board and mdf... lol).
I know you were just trying to make a bunch of "the bomb" threads, but this isn't a very good suggestion to people that have never used this type of glue.  I personally think you are better off with wood glue for your wood to wood joints.
« Last Edit: November 10, 2003, 11:52:58 pm by Wienerdog »
This opinion was created from 100% post consumed information.
Cisco Kid
« Reply #4 on: November 10, 2003, 11:51:33 pm »
yup ... definitely good stuff
I just used good ol' Titebond yellow glue with my control panel ... everything else was clear zinc-plated screws from Woodcraft ... no need to use glue when your using those babies   :)
Ghoul
  • Last login:September 15, 2004, 08:59:06 am
  • Karate Fish Master
« Reply #5 on: November 11, 2003, 12:28:19 am »
You know you have 4 topics on the front page that say "X is the bomb!"
- Party Pooper
soslo
  • The Governator
« Reply #6 on: November 11, 2003, 12:30:42 am »
are you serious!?!
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #7 on: November 11, 2003, 08:17:34 pm »
if you paint elmers white glue on your hand real thin, let it dry, then roll it up, it's fun..
Rubber cement is the same but it looks gross.
it's the bomb.    ::)
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
Wienerdog
« Reply #8 on: November 11, 2003, 10:55:09 pm »
it's the bomb.    ::)
I wonder if that works with Polyurethane glue, let us know...
1UP
  • Token Junkie
    • 1UPArcade
« Reply #9 on: November 11, 2003, 11:39:46 pm »
I don't see anything wrong with the polyurethane.  You just have to be smart about keeping it away from exposed edges.  Like someone said, the cleanup is easy, just let it dry and scrape the excess away with a putty knife.
It gave me a rock-solid join on my melamine.  I actually had to remove a section of 1x1 at some point, and although I removed all the screws, I still had to pound a putty knife into the joint to wrench it free!  Strong stuff.  That cab's not coming apart unless it gets hit by a truck.
My other job...
Wienerdog
« Reply #10 on: November 11, 2003, 11:46:53 pm »
I agree it gives you a rock solid join, but it may not be the right tool for the job.  It is more expensive and doesn't clean up with water.
I do conceed that it could help out if you have some loose joints because it will foam and fill in the void.  I also agree that it will give you a solid joint.  It just seems like overkill to me.
ErikRuud
« Reply #11 on: November 12, 2003, 10:30:29 am »
Polyurethane is one of the strongest glue types there is for wood working. It is the moisture in the wood that makes it harden.  The moisture in your skin is what causes it to cure on your hands.  When it cures it tends to lock into the pores in the wood (or your hands), that is part of makes it such a strong glue.
It is reaslly not that good for non-porous surfaces.  I would not have used it for the t-moulding.
Wear gloves while using it.  You can clean up un-cured glue with denatured alcohol.
As I-Up says, you need to learn how much to use to minimize the foaming out of the joins.
WeinerDog,  Polyurethane glues are really not good for joints with gaps.  It will fill the gap with foamed polyurethane, but the foamed glue is substantially weaker than the glue in a tight joint.
American Laser Games Wrapper
O2em Rom Utility
