Author Topic: Project Arc4de  (Read 17599 times)
mathdufort
  • Last login:September 30, 2019, 04:00:50 pm
  • waka waka waka
Project Arc4de
« on: May 01, 2013, 08:56:46 am »
Hi everyone,
Finally I'm ready to talk about our project.  I say our project because we are four friends who decided to build an arcade machine... each.  One design, 4 machines.  I'm the R&D guy so I read pretty much all of the threads here and on other sites, looking for the one design that everyone would agree on.  I found the perfect one when I stumbled upon Martijn Custom Street Fighter Arcade Cabinet.  A really sweet and professional looking design based on the global arcade classics.
For the controls we are going for a 2 players control panel with a 8 buttons each (gold leaf) layout and J-Stick (4/8 way) joysticks.
One guy on the team did all the plans in sketchup and last sunday we did all of the wood cutting.  We each bought 2 sheets of 3/4'' plywood for the sides, the bottom and the tv support, and 1 sheet of 5/8'' plywood for the control panel and the centers pieces of the cabinet.
Here are some pics of the project and I will be updating this thread with new pics and details as time goes.
The plan in sketchup:
My test control panel
A little jigsaw around the template before routing
Finished routing the sides
Sanding the control panel to get some sexy curves
Getting a glimpse of the future!
The next steps are :
  • Laminating all the center pieces
  • Creating the support for the TV
  • Putting all the pieces together
  • ...and much more
We are really excited about this project and I can't wait to play!!!!
Thank you for your support and stay tuned!
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #1 on: May 01, 2013, 09:01:41 am »
Four full-size cabinets at once!  :dizzy:
By the way, I think now would be the perfect time to cut the T-molding slots on those side panels.
« Last Edit: May 01, 2013, 10:19:56 am by Yvan256 »
rablack97
Re: Project Arc4de
« Reply #2 on: May 01, 2013, 09:09:20 am »
Look here for some laminate ideas....
http://forum.arcadecontrols.com/index.php/topic,130836.0.html
nope no t-molding cuts yet, they have to laminate first to account for the width of the laminate so it will be flush on both sides....He will need to laminate a test piece.  Route and fit the t-molding to flush on the inner piece if thats all he's doing if doing both sides, he will need to laminate both sides for the test piece and then find the center.
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #3 on: May 01, 2013, 09:24:22 am »
By the way, I think now would be the perfect time to cut the T-molding slot on those side panels.
Yes sir! 4 at once.  We really are motivated hehe  :laugh:
As for the slot for the T-Molding you are right, it will be one of the next step, I just forgot.  I do have a question though.  Here in Canada I can only find 3/32'' slot cutters and I was wondering if I really have to get a 1/16 to get a thight fit or if the 3/32 will do just the same.
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #4 on: May 01, 2013, 09:27:18 am »
Great tips thanks.  We will laminate the visible parts on the inside of the cabinet and all of the outside + the center pieces.
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #5 on: May 01, 2013, 10:22:31 am »
I can't even remember where I got my T-slot cutter bit... maybe I ordered it from the same place as my T-molding? If I can find it, I'll measure it with my digital caliper.
From your family name, may I assume you're in Québec?
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #6 on: May 01, 2013, 10:37:16 am »
Indeed I'm in Québec (not the city but the Province)!  For the T-Molding I know t-molding.com sells a 1/16'' slot cutter and we'll probably order one from them along the t-molding for our cabinets.
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #7 on: May 01, 2013, 11:48:29 am »
That's where I ordered my T-molding and slot cutter bit. Good selection and service. I would order from them again, but then again I still have plenty of T-molding in a lot of colors, probably enough for a few full-size cabinets.
« Last Edit: May 01, 2013, 11:50:20 am by Yvan256 »
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #8 on: May 01, 2013, 01:13:01 pm »
Speaking of cabinets, I've been looking at your MVS-99-6 project and damn that is sweet!  I really like the mini buttons you got for the top of the control panel.  Can theses buttons be used in 5/8'' wood or does the panel has to be thinner?
sabreerbasAlpha
  • Remember those big 10ps?
Re: Project Arc4de
« Reply #9 on: May 01, 2013, 01:31:49 pm »
4 At once..DAMN..!!! Will be watching this one. Good luck mate, I bet they will look sweet though,,,,
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #10 on: May 01, 2013, 02:13:56 pm »
Thanks for your kind words! 4 brains and 8 hands can come in handy to overcome all the bumps in the road of building an arcade cabinet!  ;)
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #11 on: May 01, 2013, 02:24:15 pm »
Thanks for the compliment, but that project is far from over. The small buttons are meant for metal panels, however I'll be snapping them on the thin plexiglass/lexan that will cover the control panel.
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #12 on: May 01, 2013, 02:52:28 pm »
Ok so since I'll be using a plexi layer on my control panel I guess could drill a larger hole in my 5/8'' sheet and snap those buttons on the plexi?
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #13 on: May 01, 2013, 03:51:21 pm »
Depends on the thickness of the plexiglass. Keep in mind those are really, really small buttons.
But since you're building full-size cabinets, if all you want is smaller buttons for other functions you could simply use 24mm buttons instead of 30mm.
edit: I think you have a personal message to reply to, Math. ;)
« Last Edit: May 01, 2013, 04:11:10 pm by Yvan256 »
sabreerbasAlpha
Re: Project Arc4de
« Reply #14 on: May 01, 2013, 04:33:07 pm »
Im sure you will do a great job.
fablog
  • Last login:Yesterday at 06:59:35 pm
Re: Project Arc4de
« Reply #15 on: May 01, 2013, 06:26:44 pm »
Hey Math,
I'm from Montréal, where do you live?
Good luck With your project, I'm working on mine too http://forum.arcadecontrols.com/index.php?topic=132082.0
« Last Edit: May 01, 2013, 06:29:41 pm by fablog »
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #16 on: May 01, 2013, 08:51:54 pm »
Hey Math,
Hey I live in Chicoutimi.  Nice to hear about your project.  It seems to be going well!  Good luck to you too!
Yvan256
    • Yvan256
Re: Project Arc4de
« Reply #17 on: May 01, 2013, 11:56:40 pm »
I'm in La Tuque, sort of half-way between both of you.  :D
gabrielvieira96
  • Last login:August 04, 2013, 11:00:16 am
Re: Project Arc4de
« Reply #18 on: August 03, 2013, 10:03:37 pm »
I am a beginner in building cabs arcades, please could you share the file with the measures of the cab to try to do it.
sorry typing errors I am Brazilian and I do not know much English.  :dunno  ??? :hissy:  :dizzy:
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #19 on: February 10, 2014, 01:40:14 pm »
It's been a while since I've posted news in this thread but the project is still ongoing.  Two of the four cabs are serving as test pilots for the other two (those are still in 2 neat piles of wood hehe).
Since my last post we've been hard at work.  We assembled my cabinet to check every pieces were properly cut.  Everything is screwed together using pocket holes which is really sturdy and fast.
Kreg tool for drilling pocket holes
Assembling the cabinet
Cabinet standing up!
More to come in a future post
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #20 on: February 10, 2014, 01:52:07 pm »
My friend Denis (member of team) did a lot of work on his cabinet, creating a support for the TV, taking measures for the marquee light, creating the support for the wheels, etc.
I used his results and did the same thing on my cabinet during my X-Mas vacation.  I also bought speaker covers from jammaboards and order the missing parts from Suzo Happ (coin door, marquee retainers, coin door lights, cabinet handles, legs, etc.).  Here are a couple photos of the progress.
Testing the TV
Rear view of the TV support
Prepping for spray painting
Pacman themed speaker covers
Outside view of fan
Inside view of the marquee light and top fan
Leg
More to come soon!
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #21 on: February 10, 2014, 02:08:43 pm »
The next step I did was prepping the coin door and the power socket.  I ordered a fake coin door from Suzo Happ, well in fact a real door but without the mecanism.  Using Denis' idea I bought a metal plate, cut it to size and bent it to create a support for the reject buttons' lights.  I then used a thin metal strip to create 2 actuator arms to use with the reject buttons which are now repurposed to credit buttons.
I ordered some C14 sockets from DX.com and wired everything up.  I then installed the coin door and the socket in my cabinet.
C14 socket working!
C14 Socket Wiring Diagram
Coin door parts
Custom made light & switch holder
Lights!
Coin door installed
Coin door installed close up
Coin door rear view
Power socket and power button close up
Still more to come later... stay tuned!
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #22 on: February 10, 2014, 02:21:38 pm »
With this last post this thread will be up to date with our current progress.
The last things I did includes creating and printing my final button layout, creating some custom reject button art, cutting some mdf to make a shelf for the computer and cutting the back panel of my cabinet to create the access door.
Final button layout
Push for credit
Push for credit close up
Rear door opening
That's it for now!  We still have plenty to do to play our first pac-man tournament!
Re: Project Arc4de
« Reply #23 on: February 10, 2014, 02:32:56 pm »
Having that power button on the lower back of the machine is probably going to get old fast, even faster if the kids know it's there.
I like them on top the cabinet because that's where most power switches were on the old games.
You could also put it inside the coin door so that it can't be turned on without the coin door key.
Otherwise, looks awesome.  carry on.
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #24 on: February 10, 2014, 02:36:55 pm »
I'm not too worried about the kids and since my son was already playing rampage by is own on my test setup I'm happy he'll be able to power up the machine alone and get playing!  Thanks for the comments!
EMDB
  • Project RetroCade
Re: Project Arc4de
« Reply #25 on: February 10, 2014, 02:57:16 pm »
Nice progress!
Another disadvantage of the power connector placement is that you can not put your cab close to the wall. My switch is on the top and a fixed cable is going through the bottom...
Re: Project Arc4de
« Reply #26 on: February 10, 2014, 03:05:31 pm »
Have a DX link to that C14 socket?
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #27 on: February 10, 2014, 03:36:45 pm »
Thanks for the comment!
Well the back of the cab is at an angle so this won't be an issue! (you can check the first few pictures of the thread)  ;)
Here's the link to the part I ordered : http://dx.com/p/2-in1-ac-250v-10a-flat-plug-power-socket-outlet-w-3-pin-on-off-rocker-switch-fuse-5-piece-pack-143505
KevinFlynn
  • Last login:March 04, 2024, 11:10:15 am
  • Greetings Programs!
Re: Project Arc4de
« Reply #28 on: February 10, 2014, 04:51:10 pm »
Sorry, just saw the link to C14 sockets... Thanks!   :cheers:
Do you have an extra one you could part with?  Nice build by the way.  Looking good!!
« Last Edit: February 10, 2014, 04:57:31 pm by KevinFlynn »
One quarter at a time...
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #29 on: February 10, 2014, 06:26:26 pm »
I'm sorry but since we are making 4 cabinets there's only one left and I'm keeping it for a future project.   :D
KevinFlynn
Re: Project Arc4de
« Reply #30 on: February 10, 2014, 06:48:07 pm »
No worries.  They're cheap enough.  I'm guessing the shipping is actually more than the order of 5.  Thanks!
  • Online Online
  • Last login:Today at 12:26:01 am
Re: Project Arc4de
« Reply #31 on: February 10, 2014, 07:06:32 pm »
You can get them on eBay or Amazon for a good price.
rablack97
Re: Project Arc4de
« Reply #32 on: February 10, 2014, 09:29:44 pm »
Yep i i buy all mine from ebay......
KevinFlynn
Re: Project Arc4de
« Reply #33 on: February 11, 2014, 10:18:15 am »
So I know this is off the subject, my apologies. I found the switch on ebay and yes, they're cheap.
Thank you mathdufort for the great pics of your build and how to wire the switch. That's helpful but I'm still nervous at the thought of installing one. I had used a power strip that I took apart and rewired the switch to the front of my cab. I would like to use the same power strip and simply wire it to the c14 switch. There are 2 wires, red and black that I would need to wire up. Of course there's prob a ground as well.
Does this sound possible or is it possible my cab will spontaneously combust?  :timebomb:
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #34 on: February 11, 2014, 10:59:12 am »
I'm no electrician but normally you just have to look up my wiring diagram and plug the red (positive) wire in place of the white (in my diagram).  You should also have a ground wire in your power strip and it should be connected to the groud on the C14 socket.  Good luck, keep a bag of marshmallows near just in case!  ;)
BAMBOO
Re: Project Arc4de
« Reply #35 on: February 13, 2014, 12:46:48 am »
My kids love the Pac-man speaker covers.  Those rock.   :applaud:
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #36 on: February 13, 2014, 09:28:07 am »
Thanks! I'm going for a Pac-Man theme and I'm putting 2 led pushbuttons between the speaker covers to act as pac dots / volume buttons =)
gabrielmtl
  • Last login:March 18, 2016, 10:19:03 pm
  • This is...
Re: Project Arc4de
« Reply #37 on: February 13, 2014, 02:03:20 pm »
Looking good, fellow quebecer. Keep it up!
dlaventu
  • Last login:March 12, 2021, 09:35:54 am
  • Soon!
Re: Project Arc4de
« Reply #38 on: July 14, 2014, 09:09:26 am »
Update comming soon! :) One cab almost complete!
mathdufort
  • waka waka waka
Re: Project Arc4de
« Reply #39 on: July 16, 2014, 08:41:31 am »
Things are going great for my build!  Following dlaventu's path, I began gluing and routing the laminate last week.  This is a very time consuming process but the results are amazing!  I also installed the PC on the shelf.  Here's the update in pictures!
More updates coming soon!
