Author Topic: weird direct3d lag issues  (Read 3130 times)
Magilla
  • Last login:September 21, 2013, 06:03:44 pm
« on: May 01, 2013, 01:07:18 am »
*edit- Mame .148 the computer can run modern games fairly well, except i threw in an ati x300 video card because im using a CRT TV and ive heard they are good for that. im sure its something to do with the video card.
With direct3d enabled games such as gunforce and metal slug have tons of video lag, no input lag or anything. when I turn it off the gamnes runs SUPER fast its funny but annoying. I have tried searching the forums but the search function isnt much help.
« Last Edit: May 01, 2013, 01:09:17 am by Magilla »
Magilla
Re: weird direct3d lag issues
« Reply #1 on: May 01, 2013, 01:33:58 am »
AMD x64 5800 dual core 2.81ghz
ati x300
4gb ram
windows xp 32bit (i dont have a good copy of 64bit)
i have tried many combination of directdraw/direct3d etc and gone through the mame help suggestions but am still running into the same issue.
Haze
    • MAME Development Blog
« Reply #2 on: May 01, 2013, 07:39:07 am »
try -nomt (I believe -mt was turned on by default in 148, but it causes problems for some people)
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: May 02, 2013, 12:38:36 am »
What's mt?
-Banned-
Magilla
« Reply #4 on: May 02, 2013, 01:36:57 am »
Thanks for the reply. I too am wondering what mt is, im really new to mame.
Is the command for the .exe or do i enter that in the program somewhere
« Reply #5 on: May 02, 2013, 09:07:52 am »
Add it to your command line
mame.exe -nomt
It's multi-threading.
I'm just a dumb end-user, so I can't tell you why it causes issues depending on hardware and what options are enabled.  :P
  • Last login:Today at 02:27:29 am
« Reply #6 on: May 02, 2013, 07:35:41 pm »
Lag can also be caused by a few other options in mame.
Hold on and let me go down the list:
sleep (needs to be set to 0)
priority (needs to be set to 0)
Magilla
« Reply #7 on: May 02, 2013, 09:09:25 pm »
apparently gunforce 2 lagged in the original, so this is accurate. kinda stupid but thats what im finding on other sites.
« Reply #8 on: May 02, 2013, 10:29:34 pm »
Same goes for some in the Metal Slug series.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #9 on: May 04, 2013, 10:44:54 pm »
Oh. Despite using an old P4 and Gforce 6800....or maybe because of them......I never have any of the issues people have with current MAME, and I rarely run from the command line anymore.
-Banned-
« Reply #10 on: May 04, 2013, 11:09:32 pm »
That's most likely because you are running an old, busted version of MAME.
It's like bragging that you can run the pc version of sf2 on your machine when others are referring to problems, with SF X Tekken.  Apples and Oranges man.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #11 on: May 08, 2013, 08:11:46 pm »
I'll re-write it to make sure there's no possibility of discrepency: I do not have any issues with current MAME on my old rig.
-Banned-
Lilwolf
« Reply #12 on: May 09, 2013, 06:28:23 am »
are you ONLY having problems when going to the TV?  Have you tried a VGA monitor with the ATI?  I'm wondering if its the component out, or the TV circuitry itself (I had this happen with a component -> tv input lagging a bit, making my remote for my directtv a pain.  No problem watching tv, but the lag made controls hard to use)
Chris John Hunter
« Reply #13 on: May 29, 2013, 10:18:46 am »
Either that or your rams ---fouled up beyond all recognition---. Im not sure about ATI x300 being good for CRT either. I had one of those came with a machine I had it was shite.
when I turn it off the games run SUPER fast its funny but annoying. I have tried searching the forums but the search function isn't much help.
This is you've disabled throttling. There is a tick box somewhere in Mame. Must be on the display tab but I cant look ATM. Which slows down the frame rate when older games go mental like 400/500% speed of originals.  What you did is. Got trouble with some games not working, played with the options and unchecked it. Did this exact same thing myself. Spent a day pulling my hair out.
