Author Topic: Trimming marquee plexiglass  (Read 3056 times)
epetti
  • Last login:September 14, 2023, 10:15:20 pm
« on: April 28, 2013, 12:56:28 pm »
I ordered a marquee from Game on Grafix sandwiched between two sheets of plexiglass.  The one sheet ended up being about 1/8" longer than the other, and while the shorter one is a perfect fit, the longer one is 1/8" too long to fit.  What's the best way to trim off such a small amount?  Saw, file, sand?  Any risk of cracking it?  Any help appreciated before I try something random and break it.
Thanks.
Re: Trimming marquee plexiglass
« Reply #1 on: April 28, 2013, 01:53:51 pm »
I'd use a table saw if you have one, and I'd put that one you cut on the back side.
EightBySix
« Reply #2 on: April 28, 2013, 03:51:38 pm »
Most woodworking tools can be used on plexiglas. I used a plane in a similar situation. Course grade sandpaper will work too. Be careful to hold/clamp it firmly, close to the edge you're working on
epetti
« Reply #3 on: April 28, 2013, 05:48:42 pm »
Went with a much more primitive solution -- scored it with an exacto knife a few times and then snapped off the edge with pliers.  Worked great.
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #4 on: April 28, 2013, 06:41:37 pm »
I would have just flushed it with the router and flush cut bit. You would have had a virtually 100% copy, but you sorted it all the same.. :applaud:
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #5 on: April 30, 2013, 11:41:30 am »
This is pretty much the defacto way of doing it and it works quite well.  Router/table saw work well too but the scoring process is always money if you have the time and patients.
