Author Topic: Interest Check: Jamma Adapters (Capcom, Taito, Nintendo) [CO, USA]  (Read 14950 times)
CraftyMech
  • Last login:July 29, 2023, 08:08:45 pm
  • I love the smell of solder in the morning...
    • craftymech.com
I realized last week I have a stack of untested boards that I need to build adapters for. There are sources for adapters of all stripes, but they usually run between $30-$60. Since I like rolling my own solutions, and believe in inexpensive products that work well, I'm considering a run of adapters for the following:
Capcom classic (Commando, Gunsmoke, Ghosts & Goblins, etc.)
Mr. Do, Lady Bug, etc. (Universal) w/ 2watt amp
Konami Classic (Rush n Attack, Time Pilot, Gryuss, etc.)
Nintendo w/ 2w amp + RGB inverter w/ adjustment pots (Popeye, DK, Mario Bros)
Taito classic (Bubble Bobble, Arkanoid, Legend of Kage, Elevator Action, Jungle King)
Prices would be $25 - $35, possibly a little bit more for the Taito adapter (needs an additional Molex power connector).
Let me know if there is an adapter you are looking for that is not mentioned above!
« Last Edit: July 31, 2013, 04:00:26 pm by CraftyMech »
BitKit 8bit FPGA Multi - http://craftymech.com
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
I am looking for a Taito to Jamma adapter for an Tournament Arkanoid board.
Thanks,
-SP
CraftyMech
    • craftymech.com
Is that a single board, and is there a separate power header, or is there just one edge connector?
southpaw13
  • Whatever!
I will post a pick tomorrow ;D
retrostark
  • Last login:February 06, 2017, 03:48:51 pm
  • Indie Dev/Custom Arcade Cabinet Hobbyist
    • RetroStarkCustomCabs.com
I want that bubble bobble
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
Does "Taito Classic" include Qix?
Single board, separate power header.
« Last Edit: April 28, 2013, 12:14:17 am by Nephasth »
CraftyMech
    • craftymech.com
Thanks for the pinout Nephasth. How was the RMPS? Going tomorrow and meeting up with Sharpfork.
Looks like Bubble Bobble & Arkanoid are Taito "classic", but Qix/Zookeeper has a set of different connectors.
I've updated the original post with a partial list for Taito.
Good times. I played damn near all the pins set up on Friday. Was pretty good early this morning, but it got WAY crowded by 11, so I headed back early. 1UP was badass Friday as well, never had a chance to make it to the 2UP though.
southpaw13
  • Whatever!
Here is a pic of Arkanoid tournament.
-SP
CraftyMech
    • craftymech.com
Thanks for the photo SP, definitely looks like the Taito "Classic" pinout that Bubble Bobble has as well. The only existing adapter I could find for sale was on eBay for $60! I think I definitely will be able to produce an adapter at a much better price point- probably around $35.
I'd be interested in a parts kit for a Taito "Classic", depending on price (I already have the Molex parts though). I like fiddling with ---steaming pile of meadow muffin---. ;)
  • Last login:February 20, 2026, 04:34:18 pm
Wait, are you talking about manufactured adapters, PCB types? Similar to the ones out there, but for cheaper?
If so, I'd be in for a Capcom 1942 adapter to replace my ugly wired one!
Konami Classic (Rush n Attack, Time Pilot, Gryuss, and a bunch of early games)
Do you think you'd be able to add additional tap points for stereo sound output on the adapter somewhere?  I bought  the Konami Gyruss adapter that's out there, and only outputs mono-sound through the JAMMA pinout. While this is good for most Jamma cabs, there are some cabinets (like sit-down candy cabs, or the dynamo "q-sound" enabled cabinets) that support stereo speakers, and it would be nice to have the option to output stereo sound from Gyruss.
Bach's Toccata and Fugue in D minor doesn't sound that epic through mono sound while shooting the ---steaming pile of meadow muffin--- out of those aliens.  ;D
« Last Edit: April 29, 2013, 03:28:04 pm by opt2not »
CraftyMech
    • craftymech.com
Definitely looking at manufactured pcbs for the adapter boards, I don't have the patience for all that hand wiring!
Interesting though regarding stereo output for the Konami "classic" adapter.  I dont think it would be an issue at all to add stereo output, either through unused pins, or a stereo phono plug, or both. I'll look into it and let you know!
CraftyMech
    • craftymech.com
If you already had the molex header, I could send you just the adapter board. Then you would just need to solder in the wires from your header into the right spots. So I think that would take the cost down, but I won't know numbers for sure until I look at laying out the boards and determine the fabrication costs.
There are Konami adapters out there that support the second speaker, but one channel still goes through the JAMMA edge while the other is meant to be wired externally:
But what would be nice is to have both channels accessible through solder points on the board, we can solder headers to it and make our own breakout cables for. The PS360+'s (those akishop multi-console controller adapters) do this type of thing with their on-board USB breakout. You have to add your own header for a connector if you so choose.
Looking at the Gyruss pinout, pins 2+B are for the Right Channel, 15+S for the Left. It shouldn't be too hard to re-route those pins to solder points, right?:
CraftyMech
    • craftymech.com
Thanks for the photos, I don't think that would be a problem either. Just a matter of designing the pcb to have those solder points.
I also double checked 1942, and although the pin count is the same, it turns out that the board does not follow the Capcom "classic" pinout :(
I updated the Capcom classic game list to remove 1942.
southpaw13
  • Whatever!
Hello, yes I want one for Arkanoid.
Thanks,
-SP
CraftyMech
    • craftymech.com
Thanks,
-SP
I've started on the Taito Classic prototype, I'm just waiting on the molex headers from digikey. I've been wanting to build one forever for a Legend of Kage board I have, so I think this adapter and the Konami Classic will probably be the first two that I build for sale.
Any update?
CraftyMech
    • craftymech.com
My molex came in last week, and I've starting working on the Taito adapter. Should have a prototype done in a couple of days and ready to test on my Arkanoid board.
CraftyMech
    • craftymech.com
I've been working on the Taito Classic (Arkanoid/Bubble Bobble) Jamma adapter, and I definitely need a better crimping tool. The one I have works fine for the small molex crimp ends, but for the .156 it does not get the job done!
I also built a Mr. Do/Universal Jamma adapter, and it works great. I'm using powered PC speakers on my test bench, so the non-amplified sound is not a problem, but I'd like to add a small 2-3 watt amp circuit for amplified sound on the Jamma +/- speaker connections. Of course the big question for this adapter is if anybody really needs one? Mr. Do is a popular classic, but I don't see many requests for Jamma adapters on the various forums.
« Last Edit: May 18, 2013, 04:26:33 pm by CraftyMech »
southpaw13
  • Whatever!
Dont forget that I want the first Arkanoid one!!!
myntik1
  • Last login:April 26, 2021, 12:03:28 pm
  • I'm part Jerry Lee and part Jerry Lee Lewis
sign me up for a konami and a taito classic
full-time sucker for part-time pay
CraftyMech
    • craftymech.com
JammaBoards may have beaten me to a Konami Classic adapter with external 2 channel support for Gyrus, and at a good price:
http://bit.ly/12E3hIK
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
Would it be possible to make a Sega System 16 to JAMMA adapter?  Not sure if the interest on that is high enough, but it's very simple.  No on board logic necessary, just remapping the pinouts.
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
CraftyMech
    • craftymech.com
I'll have to check the pinout for the System 16 boards. I have a Sega "Gigas" board I've been meaning to build an adapter for, although that might not be System 16. If there was a demand for this adapter I could definitely make one.
Bob Roberts sells a DIY kit like so...
TravistyOJ
  • DRK LFG!
Thanks!  If I'm the only one that wants one, I may do that. :)
-Douglas Adams
TravistyOJ
  • DRK LFG!
That game is Sega System 8.  Sega System 16 looks like:
              Component Side   Pin #     Solder Side
                         GND   1   A     GND
                         GND   2   B     GND
                 +5 Volts DC   3   C     +5 Volts DC
                 +5 Volts DC   4   D     +5 Volts DC
                +12 Volts DC   5   E     +12 Volts DC
                Coin Meter 1   6   F     Coin Meter 2
                               7   H
          Player 1  Switch A   8   J     Player 2  Switch A
          Player 1  Switch B   9   K     Player 2  Switch B
          Player 1  Switch C   10  L     Player 2  Switch C
                               11  M
              Player 1  Down   12  N     Player 2  Down
                Player 1  Up   13  P     Player 2  Up
             Player 1  Right   14  R     Player 2  Right
              Player 1  Left   15  S     Player 2  Left
                               16  T
                               17  U
                               18  V
                               19  W
             Coin Switch  1    20  X     Player 1  Start Switch
             Coin Switch  2    21  Y     Player 2  Start Switch
                Test Switch    22  Z
             Service Switch    23  a
                Speaker (+)    24  b     Speaker (-)
                Monitor Red    25  c     Monitor Green
               Monitor Blue    26  d     Composite Sync
                        GND    27  e     GND
                        GND    28  f     GND
-Douglas Adams
Been quiet on the Taito adapters, but I'm still interested in a DIY kit if you're willing to offer them like this, 2 now actually.
CraftyMech
    • craftymech.com
Still working on the Taito adapter! I've been sidetracked by working on getting a new version of the mini SLG ready (running out of the current version). I need to order a better crimper for the .156 molex pins.
I've built a prototype that works fine with my Arkanoid board, so I just need to do the pcb layout.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
I'd take a Taito Classic adaptor - I've got an Arkanoid + spinners that have been sitting on the shelf for far too long.
CraftyMech
    • craftymech.com
I've been sidetracked recently with the mini SLG 2, but I managed to finish the prototype of my Taito Classic adaptor!
I've tested the adapter with Arkanoid, and Legend of Kage. So now I need to put the pcb design together, and figure out if there is enough interest to produce the boards.
Since it has been awhile, if you don't mind chiming in again if you still are looking for a Taito Classis adaptor, that would be great.
« Last Edit: July 31, 2013, 03:57:18 pm by CraftyMech »
CraftyMech
    • craftymech.com
And here is a shot of Arkanoid running on my new (to me) 15k test monitor. The monitor is an old Apple RGB model that I picked up for $30 :)
The black/gray shells on the cable connection may look a tad familiar if you are a mini SLG user. I saved the scratched and damaged cases for use as strain relief on my DIY cables.
« Last Edit: July 31, 2013, 03:54:14 pm by CraftyMech »
Re: Interest Check: Jamma Adapters (Capcom, Taito, Nintendo) [CO, USA]
« Reply #35 on: July 31, 2013, 04:13:34 pm »
Sorry Crafty, I got impatient and ended up making my own last week. :-\
Your adapter looks great! :applaud:
southpaw13
  • Whatever!
« Reply #36 on: July 31, 2013, 08:44:32 pm »
Yes, still want one!  I was first on the original list  :)
Southpaw
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« Reply #37 on: July 31, 2013, 11:40:19 pm »
You should try whipping up a Nintendo Vs to JAMMA, or Playchoice to JAMMA adapter.  Lots of those boards out there in the wild too.
cools
    • Arcade Otaku
« Reply #38 on: August 01, 2013, 04:46:47 am »
I definitely still want an adapter for Arkanoid. I may even take a few if the price ends up being good - shipping to the UK will be the worst bit.
CraftyMech
    • craftymech.com
« Reply #39 on: August 01, 2013, 12:05:27 pm »
Southpaw - The first unit made will definitely be yours!
Cools - Great, thanks for letting me know.
Raven- Mike's Arcade sells a Vs Adapter for $65, depending on what's involved I could probably develop something cheaper. I'll take a look and see what I find out.
I'm working on the pcb layout now, and identified the right parts for making the 12 pin sub connector when I put my prototype together. I also have plenty of the 44 pin edge connectors on hand for the Taito side of the adapter.
So I am thinking that by the end of the month I could be ready to sell these, I'll keep everyone posted!
« Last Edit: August 01, 2013, 12:14:03 pm by CraftyMech »
