Author Topic: Control Panel Going Lose  (Read 1501 times)
brained
  • Last login:February 11, 2026, 10:56:20 am
  • Raised by Atari
    • Nux
« on: April 22, 2013, 11:51:56 am »
Hello everybody... I have another question. I own a Dynamo HS-5 cut-corner cab. The thing is that the my control panel latch is not holding the control panel and in the middle of a game it goes lose. The thing is, I cant add any more latches because of some buttons are right in the middle of the latch notches. I've been thinking of pulling the latch a little bit into the cab to add some strength, but before I go into this ordeal I decided to ask?
Do you have any recommendations for this matter? Thanks in advance
GoYouSalukis
  • Last login:March 18, 2020, 11:58:59 am
Re: Control Panel Going Lose
« Reply #1 on: April 22, 2013, 12:53:36 pm »
Maybe you can put something like a piece of rubber inside the hook part of the clamp to make it pull down better. Maybe layers of old inner tube? Or you could put a spacer on the hole portion where the clamp goes into.
« Reply #2 on: April 22, 2013, 01:54:56 pm »
maybe just a new latch?
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #3 on: April 23, 2013, 09:59:16 am »
It sounds like the latch is a little loose.  I would follow Malenko/GoYouSaluki's suggestions.  Rubber/Plastic might help make the seal tighter or a new latch.  Then I would try moving it back.
mgb
  • North East, US
« Reply #4 on: April 23, 2013, 10:24:31 am »
+1
The latch could just be best but moving it back can most likely take care of the issue.
If the latch is not back enough, there will not be enough pressure on it and it could release
brained
  • Raised by Atari
    • Nux
« Reply #5 on: April 23, 2013, 01:39:56 pm »
Thank you all for your suggestions. I'll be moving the latch on the weekend ;)
