Author Topic: Sharp manfactures a 23.1 4:3 LCD!  (Read 2251 times)
dinofly
  • Last login:June 07, 2015, 08:38:41 pm
« on: April 18, 2013, 08:41:44 am »
Hello,
Was looking for a bartop monitor and i found this panel:
http://www.panelook.com/modelsearch.php?op=advancedsearch&order=panel_id&by=desc&pagesize=50&production_state=1&inch_low=20.0&aspect_ratio=1.33&color_saturation=-1&order=panel_size_inch&by=desc
It is for industrial use, but has a 1600x1200 resolution and a very wide viewing angles due of the strange tech it use.
The problem is, how can i order a industrial panel like that? And how to control it? I suppose it come without any electronics , osd, etc.
I realize this is a problem for many, because crt is cool but is dramatically big, and this 23.1 panel can ben very interesting!
MonMotha
Re: Sharp manfactures a 23.1 4:3 LCD!
« Reply #1 on: April 18, 2013, 03:01:27 pm »
Well, they may have at some point.  Dunno if they still do.  Good luck buying one (especially ONE).  I guess you can put out an RFQ, but unless somebody has stock, you won't be getting one.  Nobody's going to turn up a line to make ONE panel for you, especially not Sharp or NEC, at least not at any price you're willing to pay.
Panel interface appears to be LVDS/OpenLDI/PanelLink.  This is quite common internally but is not a consumer standard.  You'll need some sort of scaler/driver board.  They're not overly complex, but they can cost a pretty penny.  Somebody did recently find some on eBay direct from China for like $25 that took DVI or analog RGB (VGA).  YMMV with those.
Honestly, I'm far more intereted in the NEC one at 2560x1600.  That's an actual improvement over what I had 10 years ago.
dinofly
« Reply #2 on: April 18, 2013, 05:14:43 pm »
Obviously i can't buy ONE (a box contains two panels BTW), but if many are interested maybe we can pool. Because this is simply the BIGGEST 4:3 LCD display in production by now.
http://www.data-modul.com/tl_files/dm/data/specification_SD20931.pdf
There are problems regardin alimentation too, with strange ports that i never heard lol.
« Last Edit: April 18, 2013, 05:16:51 pm by dinofly »
sandheaver
« Reply #3 on: April 26, 2013, 11:40:21 am »
Note that they are PANELS and not MONITORS.
You'll need to provide a backlight inverter, OpenLDI signal, etc.; all the supporting infrastructure required to make the monitor function.
  • Last login:Yesterday at 11:14:57 am
« Reply #4 on: April 26, 2013, 02:58:20 pm »
maybe rickn would like to take this project on?
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
« Reply #5 on: April 26, 2013, 03:33:37 pm »
Just look for a Sammy 214t on eBay, 21.3" IPS 178 degree viewing angle in both planes, same resolution, looks amazing, I put one in Little Ms. Pac-Man, found it on eBay for $60+ shipping
« Last Edit: April 26, 2013, 03:39:28 pm by Maximus »
dinofly
« Reply #6 on: April 26, 2013, 09:55:41 pm »
Actually it uses a LVDS interface, controller board like this are common on ebay: http://www.ebay.com/itm/LVDS-VGA-DVI-AV-HDMI-LCD-controller-board-DIY-2662-/271178093976?pt=US_Server_Boards&hash=item3f23795598
And it's just led backlit no need inverter, but i don't get if is possible to connect it at a standard atx psu. I'm not good enough in electronics...
Gray_Area
  • -Banned-
  • -Banned-
« Reply #7 on: April 28, 2013, 06:10:41 pm »
If it's got pins, yeah likely you can and easily.
-Banned-
