Author Topic: Hyperspin Hyperpin Nightmare  (Read 1643 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: April 13, 2013, 04:48:25 pm »
I've spent the best part of a day trying to get hyperpin set up with 2 monitors (What a nightmare having to put files for the table all over the place and then having to edit the table code  :dizzy:)
finally I got it to work. Now I want to add this to my hyperspin set up so I can select it the same way I would select any other system, also Id like to get it to rotate my monitor the same way as I have the MAME emu rotating it. Moved it from C:Hyperpin\ to C:\HyperSpin\Emulators\Hyperpin and now it doesn't work, even if I launch it direct from there I can see a table but when I press enter to launch it flickers and brings me back to the table selection screen. As for Hyperspin, I used HyperHQ to add a system "Pinball" and selected Hyperpin.exe as the executable, when I select Pinball from the main wheel I get "Make sure your paths have a backslash on the end" error.
My head hurts  :banghead:
Connorsdad
Re: Hyperspin Hyperpin Nightmare
« Reply #1 on: April 13, 2013, 06:53:20 pm »
Not sure which of the many things I tried worked but I now have Hyperpin launching from (and returning to on exit) Hyperspin, now to figure out how to make the monitor rotate  :dizzy:
