Author Topic: rowe ami diplomat j200 1965 need help installing volume control  (Read 2637 times)
glen
  • Last login:April 07, 2013, 11:37:27 am
when this juke box was removed from original location there was a remote volume/cancel control but it was cut off when moved.  i have purchased new volume control but it is not working when installed can someone give me some pointers on volume control wiring.  right now i have no ability control volume.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe ami diplomat j200 1965 need help installing volume control
« Reply #1 on: April 08, 2013, 08:08:54 am »
Hello Glen,
If you have a manual then you need to wire up the volume control as per the manual it will be a a dual 10k log control that is wired with a four core screened cable or you could use a 5 core cable if you want to include a reject button. the screen is used across both controls at one end of the control.
Regards
Alan
Alan Hood
ami-man
UK
