Author Topic: (iCade) 60-in-1 Settings issue FIXED  (Read 7288 times)
jmike
« on: April 06, 2013, 11:29:44 am »
Recently purchased an iCade 60-in-1 boards but I'm having trouble accessing the settings screen to set it to cocktail mode.
I hit "Test Switch" when powering on the board and get to the "screen adjust" page but I can't get to the next page. Instructions says to hit "Test" but that doesn't do anything. I've tried all Player1 and Player 2 buttons but can't seem to get to the next page.
The only button that does work is the "Test Switch" button again which sends me to the I/O page. There I can check to make sure all the inputs are working properly (and they are, even the "Test " button).
Can someone please tell me if there's a combination of buttons or maybe a Dip switch needs to be turned on so I can access the other setting pages, especially the one to convert it to Cocktail mode. This is one of the newer iCade 60-in-1 smaller boards.    :banghead:   :banghead:
Any help would be appreciated.
Thanks.
« Last Edit: April 10, 2013, 07:13:39 am by jmike »
mebronx2000
  • Last login:August 03, 2024, 06:20:32 pm
Re: (iCade) 60-in-1 Settings issue
« Reply #1 on: April 07, 2013, 11:24:14 pm »
player 1 button number two works for me !   :cheers:
jmike
« Reply #2 on: April 08, 2013, 07:26:42 pm »
Thanks but I tried that and it didn't work. I recall you had issues with your 60-in-1
(Trying to get both players to play with the same controls) funny cause mine is set up that way already.
Will keep trying.
mebronx2000
« Reply #3 on: April 08, 2013, 11:05:57 pm »
try and go into setup on the dip switch and not using the test button  :cheers:
jmike
« Reply #4 on: April 09, 2013, 09:05:13 am »
Without test button? You mean I can get to the settings screen just by turning on switch 4?
 :dizzy:
  • Last login:Today at 12:52:09 am
« Reply #5 on: April 09, 2013, 09:08:08 am »
Yes. I'm glad mebronx told you that. I was going to ask if you were still holding those buttons at startup, but thought 'Nah, he can't be!'  :laugh:
jmike
« Reply #6 on: April 09, 2013, 09:38:23 am »
Guilty as charged   :banghead:
Okay will try it when I get home and report back.
 :cheers: to you both
« Reply #7 on: April 09, 2013, 09:42:54 am »
jmike, do you have a copy of the manual?
jmike
« Reply #8 on: April 09, 2013, 10:41:28 am »
No. Just been going with what I read online.
jmike
« Reply #9 on: April 10, 2013, 07:13:09 am »
 :applaud: :applaud:
Finally got into the set-up screen menus. Thanks for the manual PDF Yotsuya.
Now I can start planning the cocktail build.
