Author Topic: slot cutter is the correct one?  (Read 1193 times)
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
« on: April 05, 2013, 03:45:40 pm »
Hi Guys
Would somebody be kind enough to check that this is the correct slot cutter for 3/4 t moulding before I place the order http://www.amazon.com/gp/product/B0002TUCRA/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
This is only £17.88 from Amazon delivered to the UK, if I buy from supplier here in the UK it's £28
Jeremy (DHTech)
JDFan
Re: slot cutter is the correct one?
« Reply #1 on: April 05, 2013, 04:06:52 pm »
Should be the one you need as long as your molding has the 3\32 inch spline -- As referenced in the first product review :
By Matthew C. Rings
Amazon Verified Purchase
This router bit was just what I needed for making my stand-up arcade, and routing out the edge groove for my T-molding. Great price, and much cheaper than the local home fixit store.
and from Game Molding.coms description of the one they sell that has the same 1\16th inch Kerf size ( they sell the blade and the arbor seperately and the cost is a bit higher) :
WHITESIDE MACHINE 6700A CARBIDE-TIP 3-WING SLOTTER
    Requires a slot cutting arbor which can be found in the "T-Molding Tools" section
    1-7/8 DIA X 5/16' BORE X 1/16 (.062) KERF
    Use with molding that has a 3/32" wide spine
« Last Edit: April 05, 2013, 04:12:04 pm by JDFan »
Unstupid
« Reply #2 on: April 05, 2013, 05:05:14 pm »
That one would work, but if your router can handle 1/2" shanks I'd go with this one:
http://www.amazon.com/Freud-63-150-16-Inch-Cutter-16-Inchdepth/dp/B0002TUCZW/
