Author Topic: ArcadeVGA 3000 and UEFI BIOSes?  (Read 1422 times)
wesbrown18
  • Last login:October 24, 2018, 09:29:23 pm
« on: April 04, 2013, 12:13:07 pm »
I have in my hands an ArcadeVGA 3000, installed in an AMD Llano A8 APU based system.
I appear to be having issues related to UEFI -- basically, UEFI seems to want to force the screen into a higher resolution than the initial ArcadeVGA 3000 15khz mode.  At this point, the ArcadeVGA seems to stay in 31.5khz and above mode, which makes it not work via the J-PAC hooked up to my Nanao 2931.
Has anyone else gotten an ArcadeVGA setup working with a recent UEFI BIOS that seems to force the resolution?
JoeB
  • Last login:Today at 05:49:35 pm
  • NES Fanatic
Re: ArcadeVGA 3000 and UEFI BIOSes?
« Reply #1 on: April 05, 2013, 11:02:19 pm »
Once you boot into windows you should get 15k as Andy's driver should take over from EFI. You sure you got the windows driver installed correctly and selected 640x480i?
wesbrown18
« Reply #2 on: April 07, 2013, 03:47:57 pm »
JoeB,
Thanks for the suggestion -- I'm using GroovyArcade.  It turns out that it was partially a confluence of several things:
  • UEFI wanting a higher resolution on boot -- and wanting a higher resolution than available at 15khz
  • The GRUB boot splash screen using a higher default resolution because that's what the EFI BIOS set up
  • The newer ArcadeVGA 3000 cards *may* have DVI-I instead of VGA output at the card connector level
  • This causes selecting VGA outputs from the GRUB menu to not work properly
  • The JPAC JAMMA video connector not working well with 31.5khz -- or the Nanao 2931 not working well with 31.5khz signals via the JAMMA connector
I will be investigating in more detail to see what's happening here.
Modified: Added note about JAMMA video connector.
« Last Edit: April 07, 2013, 03:55:01 pm by wesbrown18 »
