Author Topic: How to create list for 3-4 Player games on Romlister?  (Read 1710 times)
Javy3
  • Last login:June 17, 2013, 09:54:24 am
« on: April 02, 2013, 09:22:44 pm »
Hello,
I created a merged xml file and wanted to create a list that just shows games that allow for 3-4 players for easy searching at parties.  After hitting set on the xml file I noticed that my "Num players" section is grayed out.  What do I have to do to create a list that limits the games to only games that have 3-4 players?  Thanks in advance.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: How to create list for 3-4 Player games on Romlister?
« Reply #1 on: April 02, 2013, 09:43:32 pm »
that section is grayed out if RL doesn't detect that you merged nplayers.ini in.
was nplayers.ini part of the merged file process?
get the file from here:
http://nplayers.arcadebelgium.be
you'll have to re-do your merged file though.
sorry that was confusing to ya.  I'm working on a more robust merge tool at the moment and hopefully these things will rectify themselves.
Javy3
« Reply #2 on: April 05, 2013, 10:48:03 am »
Thank you for the help.  I was able to resolve my problem and now have a list for easy searching during big gaming parties.  One question, Can I use Romlister to edit the names on three games I have on Final Alpha Burn?  I have Mala as a frontend and have Jojo's adventure, SFIII and MvC on Final Alpha because they don't work with my Mame.  On mala they just show the rom name and I wanted to know if I can use Romlister to actually get the full names listed?  Thanks
NOP
    • winterMAME
« Reply #3 on: April 05, 2013, 06:00:26 pm »
You can't edit the rom names directly with romlister, but what you can do is edit the merged xml file that you're loading into romlister.
Find the 3 games you want to rename, make the edits, and then do whatever you did to get those 3 games into a list that you can then export out of romlister into a mala game list file.
