Author Topic: 7 segment LED math  (Read 1167 times)
SavannahLion
7 segment LED math
« on: March 31, 2013, 02:25:38 am »
I'm a little confused by the specs on double digit 7 segment displays(either Common Cathode or Anode, doesn't seem to make a difference).
I see that IF is usually around 20 or 30mA (I'm looking at blue) and spec sheets usually seem to imply that this is for all the segments combined. But ~25mA seems awfully low. Is it because the luminosity is crazy low compared to a single LED?
If I go the other way and say that ~25mA is for each segment, then that's +/-175mA (for each digit) getting pumped through. And that seems an awful lot too.
Any techies want to give me a hint? Remember, this is about 7 segment displays, not your ultra-bright single shots.
« Last Edit: March 31, 2013, 02:27:09 am by SavannahLion »
  • Last login:February 11, 2026, 07:46:44 pm
Re: 7 segment LED math
« Reply #1 on: March 31, 2013, 04:28:07 am »
This is just a guess mind you, but I would say it's the oddly low value.  7-seg displays are designed to use less power because they are often in clocks and thus are always on.  I know I used to trace the pins on the ones that used to come in pc cases with a single AAA battery.
Even if I'm wrong, hooking up to too low a voltage won't hurt while using the other could fry the thing.
SavannahLion
« Reply #2 on: March 31, 2013, 01:01:31 pm »
That's what I figured. I pulled out my older red display and plopped them in and drove them for about two hours without frying anything. I don't have any specs on the ones I have but I figure they likely to be less effective the blues I'm expecting.
