Author Topic: Type of wood  (Read 1642 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Type of wood
« on: March 26, 2013, 02:52:43 pm »
I'm sure this might have been asked before.....
If anyone owns an original arcade cabinet, what typically was the wood that was used?   Is it white/beige colored melamine MDF used then?
  • Last login:Today at 05:36:23 pm
Re: Type of wood
« Reply #1 on: March 26, 2013, 03:46:41 pm »
Unfortunately, your question is a little broad -- like asking what are house walls are built of.
Some use wood 2x4's, some use metal 2x4's, some use 2x6's, some use drywall, some use paneling . . .
The correct answer to your question depends on which cab you're referring to, but many cabs used laminate over plywood.
mgb
  • North East, US
Re: Type of wood
« Reply #2 on: March 27, 2013, 12:21:43 am »
the majority of old school cabs were particle board covered in vinyl.
personally i would advise the use of formica laminate over particle board or even plywood or mdf for a cab construction.
Re: Type of wood
« Reply #3 on: March 27, 2013, 11:59:28 am »
Yep, it varies, generally by manufacturer.  You're going to see mostly 3/4" MDF and plywood.
twistedsistem
  • Last login:October 08, 2019, 09:46:59 am
Re: Type of wood
« Reply #4 on: March 27, 2013, 01:05:59 pm »
MDF has been what I have used so far.  Seems to work well.
mgb
  • North East, US
Type of wood
« Reply #5 on: March 27, 2013, 08:13:17 pm »
What commercial arcade company used  mdf for their cabinets?
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Today at 06:56:49 am
Re: Type of wood
« Reply #6 on: March 27, 2013, 10:02:27 pm »
Of the various wood products I've used, I've been the most happy with MDO. Sometimes known as signboard. I'll never use anything else if I have the option.
http://forum.arcadecontrols.com/index.php/topic,110235.msg1167749.html#msg1167749
http://forum.arcadecontrols.com/index.php/topic,102064.msg1111716.html#msg1111716
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
mgb
  • North East, US
Type of wood
« Reply #7 on: March 28, 2013, 01:50:44 pm »
MDO is plywood with a mdf overlay, right?
Seems like it'd be great to use I guess because you get the lighter weight of plywood with the smoothness if mdf.
Isn't it expensive though
